iDanny
#1 Posted : Friday, March 8, 2019 7:47:18 AM(UTC)
iDanny
Ecuador
ffmpeg started on 2019-03-07 at 15:26:38
Report written to "C:\ProgramData\vMix\streaming\streaming1 20190307-152638.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 3500k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 3500k -maxrate:v 3850k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/22.0.0.50)" -f flv ""
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 352447.026000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 0460b2c0] TCP Buffer has been set to 9070592 bytes
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (62% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (64% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (69% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (71% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (73% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (76% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (78% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (79% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (81% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (82% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (83% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (84% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (86% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (87% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (88% of size: 128000000 [rtbufsize parameter])! frame dropped!
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (native))
Press [q] to stop, [?] for help
[libx264 @ 04606e80] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
[libx264 @ 04606e80] profile Constrained Baseline, level 3.1
[libx264 @ 04606e80] 264 - core 152 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=60 keyint_min=6 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=3500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=3850 vbv_bufsize=3500 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx':
Metadata:
encoder : Lavf57.82.101
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1280x720, q=-1--1, 3500 kb/s, 29.97 fps, 1k tbn, 29.97 tbc
Metadata:
encoder : Lavc57.106.101 libx264
Side data:
cpb: bitrate max/min/avg: 3850000/0/3500000 buffer size: 3500000 vbv_delay: -1
Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 128 kb/s
Metadata:
encoder : Lavc57.106.101 aac
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame= 82 fps=0.0 q=19.0 size= 983kB time=00:00:03.94 bitrate=2041.4kbits/s speed=7.87x
frame= 110 fps=109 q=16.0 size= 1889kB time=00:00:05.43 bitrate=2845.7kbits/s speed=5.41x
frame= 125 fps= 83 q=19.0 size= 2136kB time=00:00:05.95 bitrate=2941.3kbits/s speed=3.94x
frame= 141 fps= 70 q=18.0 size= 2462kB time=00:00:06.44 bitrate=3132.0kbits/s speed=3.19x
frame= 156 fps= 62 q=18.0 size= 2664kB time=00:00:06.97 bitrate=3128.8kbits/s speed=2.75x
frame= 171 fps= 56 q=18.0 size= 2903kB time=00:00:07.46 bitrate=3186.5kbits/s speed=2.45x
frame= 186 fps= 52 q=18.0 size= 3112kB time=00:00:07.99 bitrate=3187.0kbits/s speed=2.26x
frame= 201 fps= 50 q=21.0 size= 3427kB time=00:00:08.48 bitrate=3307.4kbits/s speed=2.09x
frame= 217 fps= 48 q=27.0 size= 3669kB time=00:00:08.97 bitrate=3347.5kbits/s speed=1.97x
frame= 232 fps= 46 q=28.0 size= 3925kB time=00:00:09.49 bitrate=3388.4kbits/s speed=1.88x
frame= 247 fps= 44 q=28.0 size= 4186kB time=00:00:09.98 bitrate=3435.1kbits/s speed= 1.8x
frame= 262 fps= 43 q=27.0 size= 4389kB time=00:00:10.49 bitrate=3425.9kbits/s speed=1.73x
frame= 277 fps= 42 q=30.0 size= 4634kB time=00:00:10.98 bitrate=3456.4kbits/s speed=1.67x
frame= 292 fps= 41 q=30.0 size= 4857kB time=00:00:11.51 bitrate=3454.5kbits/s speed=1.63x
frame= 307 fps= 41 q=29.0 size= 5117kB time=00:00:12.00 bitrate=3491.0kbits/s speed=1.58x
frame= 322 fps= 40 q=28.0 size= 5351kB time=00:00:12.49 bitrate=3507.4kbits/s speed=1.55x
frame= 337 fps= 39 q=27.0 size= 5571kB time=00:00:13.03 bitrate=3501.7kbits/s speed=1.52x
frame= 353 fps= 39 q=27.0 size= 5793kB time=00:00:13.52 bitrate=3509.3kbits/s speed=1.49x
frame= 368 fps= 38 q=28.0 size= 6044kB time=00:00:14.03 bitrate=3527.9kbits/s speed=1.46x
frame= 383 fps= 38 q=30.0 size= 6312kB time=00:00:14.52 bitrate=3559.8kbits/s speed=1.44x
frame= 398 fps= 38 q=29.0 size= 6528kB time=00:00:15.03 bitrate=3556.1kbits/s speed=1.42x
frame= 413 fps= 37 q=30.0 size= 6777kB time=00:00:15.55 bitrate=3570.1kbits/s speed= 1.4x
frame= 428 fps= 37 q=29.0 size= 7008kB time=00:00:16.06 bitrate=3574.2kbits/s speed=1.38x
frame= 444 fps= 37 q=29.0 size= 7186kB time=00:00:16.57 bitrate=3552.0kbits/s speed=1.37x
frame= 459 fps= 36 q=29.0 size= 7418kB time=00:00:17.08 bitrate=3556.4kbits/s speed=1.35x
frame= 474 fps= 36 q=29.0 size= 7650kB time=00:00:17.59 bitrate=3561.2kbits/s speed=1.34x
frame= 489 fps= 36 q=29.0 size= 7815kB time=00:00:18.08 bitrate=3539.3kbits/s speed=1.32x
frame= 505 fps= 36 q=28.0 size= 7881kB time=00:00:18.57 bitrate=3475.3kbits/s speed=1.31x
frame= 520 fps= 35 q=27.0 size= 7941kB time=00:00:19.09 bitrate=3407.8kbits/s speed= 1.3x
frame= 535 fps= 35 q=26.0 size= 8001kB time=00:00:19.58 bitrate=3347.3kbits/s speed=1.29x
frame= 550 fps= 35 q=25.0 size= 8129kB time=00:00:20.11 bitrate=3311.0kbits/s speed=1.28x
frame= 565 fps= 35 q=24.0 size= 8195kB time=00:00:20.62 bitrate=3254.7kbits/s speed=1.27x
frame= 580 fps= 35 q=23.0 size= 8274kB time=00:00:21.11 bitrate=3209.4kbits/s speed=1.27x
frame= 595 fps= 35 q=22.0 size= 8369kB time=00:00:21.63 bitrate=3169.8kbits/s speed=1.26x
frame= 610 fps= 34 q=22.0 size= 8551kB time=00:00:22.12 bitrate=3166.7kbits/s speed=1.25x
frame= 625 fps= 34 q=21.0 size= 8636kB time=00:00:22.63 bitrate=3125.9kbits/s speed=1.24x
frame= 641 fps= 34 q=20.0 size= 8758kB time=00:00:23.12 bitrate=3102.8kbits/s speed=1.24x
frame= 656 fps= 34 q=19.0 size= 8903kB time=00:00:23.63 bitrate=3086.1kbits/s speed=1.23x
frame= 671 fps= 34 q=19.0 size= 9146kB time=00:00:24.14 bitrate=3103.1kbits/s speed=1.22x
frame= 686 fps= 34 q=19.0 size= 9303kB time=00:00:24.65 bitrate=3090.6kbits/s speed=1.22x
frame= 701 fps= 34 q=18.0 size= 9475kB time=00:00:25.17 bitrate=3083.9kbits/s speed=1.21x
frame= 717 fps= 34 q=18.0 size= 9675kB time=00:00:25.66 bitrate=3088.4kbits/s speed=1.21x
frame= 732 fps= 34 q=18.0 size= 9966kB time=00:00:26.17 bitrate=3119.2kbits/s speed= 1.2x
frame= 747 fps= 34 q=18.0 size= 10165kB time=00:00:26.66 bitrate=3123.0kbits/s speed= 1.2x
frame= 762 fps= 33 q=17.0 size= 10383kB time=00:00:27.17 bitrate=3129.8kbits/s speed=1.19x
frame= 777 fps= 33 q=17.0 size= 10604kB time=00:00:27.68 bitrate=3137.4kbits/s speed=1.19x
frame= 792 fps= 33 q=17.0 size= 10914kB time=00:00:28.17 bitrate=3172.9kbits/s speed=1.19x
frame= 807 fps= 33 q=17.0 size= 11101kB time=00:00:28.69 bitrate=3169.6kbits/s speed=1.18x
frame= 822 fps= 33 q=17.0 size= 11355kB time=00:00:29.20 bitrate=3185.3kbits/s speed=1.18x
frame= 837 fps= 33 q=18.0 size= 11586kB time=00:00:29.71 bitrate=3194.3kbits/s speed=1.18x
frame= 852 fps= 33 q=18.0 size= 11903kB time=00:00:30.20 bitrate=3228.2kbits/s speed=1.17x
frame= 868 fps= 33 q=17.0 size= 12132kB time=00:00:30.71 bitrate=3235.3kbits/s speed=1.17x
frame= 883 fps= 33 q=17.0 size= 12368kB time=00:00:31.20 bitrate=3246.6kbits/s speed=1.17x
frame= 898 fps= 33 q=15.0 size= 12578kB time=00:00:31.69 bitrate=3250.6kbits/s speed=1.16x
frame= 913 fps= 33 q=18.0 size= 12893kB time=00:00:32.23 bitrate=3276.7kbits/s speed=1.16x
frame= 928 fps= 33 q=21.0 size= 13164kB time=00:00:32.72 bitrate=3295.7kbits/s speed=1.16x
frame= 943 fps= 33 q=29.0 size= 13426kB time=00:00:33.25 bitrate=3307.2kbits/s speed=1.15x
frame= 959 fps= 33 q=27.0 size= 13705kB time=00:00:33.74 bitrate=3326.9kbits/s speed=1.15x
frame= 966 fps= 32 q=28.0 size= 13810kB time=00:00:34.00 bitrate=3327.3kbits/s speed=1.14x
frame= 970 fps= 32 q=26.0 size= 13866kB time=00:00:34.13 bitrate=3328.2kbits/s speed=1.12x
frame= 974 fps= 31 q=29.0 size= 13942kB time=00:00:34.25 bitrate=3333.9kbits/s speed=1.11x
frame= 980 fps= 31 q=29.0 size= 14028kB time=00:00:34.47 bitrate=3333.7kbits/s speed=1.09x
frame= 984 fps= 31 q=28.0 size= 14076kB time=00:00:34.60 bitrate=3332.8kbits/s speed=1.07x
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (74% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame= 989 fps= 30 q=30.0 size= 14153kB time=00:00:34.77 bitrate=3334.5kbits/s speed=1.06x
frame= 992 fps= 29 q=33.0 size= 14225kB time=00:00:34.87 bitrate=3341.1kbits/s speed=1.03x
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame= 996 fps= 29 q=30.0 size= 14269kB time=00:00:35.00 bitrate=3339.1kbits/s speed=1.02x
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (90% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (91% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame= 999 fps= 29 q=31.0 size= 14322kB time=00:00:35.11 bitrate=3341.5kbits/s speed= 1x
[dshow @ 00118040] real-time buffer [vMix Video YV12] [video input] too full or near too full (100% of size: 128000000 [rtbufsize parameter])! frame dropped!
[tls @ 0460b080] Writing encrypted data to socket failed
av_interleaved_write_frame(): I/O error
[flv @ 04605880] Failed to update header with correct duration.
[flv @ 04605880] Failed to update header with correct filesize.
Error writing trailer ofxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxI/O error
frame= 1533 fps=2.9 q=1.0 Lsize= 73209kB time=00:06:19.04 bitrate=1582.2kbits/s speed=0.726x
video:72799kB audio:105kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.416936%
[tls @ 0460b080] Failed to send close message
[libx264 @ 04606e80] frame I:85 Avg QP: 5.28 size:180412
[libx264 @ 04606e80] frame P:1448 Avg QP:13.67 size: 42599
[libx264 @ 04606e80] mb I I16..4: 40.4% 0.0% 59.6%
[libx264 @ 04606e80] mb P I16..4: 14.0% 0.0% 3.9% P16..4: 27.4% 9.1% 4.5% 0.0% 0.0% skip:41.2%
[libx264 @ 04606e80] coded y,uvDC,uvAC intra: 50.8% 65.3% 53.6% inter: 23.1% 21.2% 12.6%
[libx264 @ 04606e80] i16 v,h,dc,p: 57% 25% 13% 5%
[libx264 @ 04606e80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 26% 16% 7% 9% 3% 3% 3% 3%
[libx264 @ 04606e80] i8c dc,h,v,p: 59% 21% 15% 4%
[libx264 @ 04606e80] kb/s:1625.10
[aac @ 04609280] Qavg: 65536.000
Conversion failed!
#2 Posted : Friday, March 8, 2019 10:42:12 AM(UTC)
@ iDanny
Was your stream button Amber and not Red?
Read this Knowledge Base article:
https://www.vmix.com/kno...mes-show-orange-or-amber
iDanny
#3 Posted : Saturday, March 9, 2019 9:02:18 AM(UTC)
iDanny
Ecuador
Originally Posted by: IceStream Go to Quoted Post
@ iDanny
no, the error is with windows update 1809, with the 1803 works fine
Jonas Wagner
#4 Posted : Wednesday, April 17, 2019 5:52:30 AM(UTC)
Jonas Wagner
Was thanked: 3 time(s) in 1 post(s)
Hi from Germany,
has there been a fix in the meantime? I upgraded from Windows 7 Pro x64 to Windows 10 Pro X64 V1809 4 weeks ago and now on my first live-stream under Windows 10 the stream was very unstable and it seems to be a question of luck if my stream ist stable or quits after 2 - 5 minutes with this message:
[dshow @ 02b27e40] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped!
Under Windows 7 I never had this issue and unfortunately I cannot go back to windows 7 :-(
Jonas Wagner
#5 Posted : Friday, November 29, 2019 9:41:50 AM(UTC)
Jonas Wagner
Originally Posted by: Jonas Wagner Go to Quoted Post
Hi from Germany,
Hi there again,
it´s been a while and in the meantime I found the bad boy which caused the problems named in my last post: It was the onboard-ethernet-card of my Gigabyte-Mainboard. For any unknown reason Windows 10 had problems to get it up and running without an issue. So I changed for a PCIe-Ethernet-card by intel and since then had no further problems!
Hope this is helpful, even 8 months after the last post in this topic.
All the best from Germany,
Jonas
thanks 3 users thanked Jonas Wagner for this useful post.
ThomasK on 3/8/2020(UTC), evansvillefirstnazarene@gmail.com on 5/4/2020(UTC), Xtreemtec Media on 5/4/2020(UTC)
#6 Posted : Monday, May 4, 2020 2:49:34 AM(UTC)
Wow, you're right on the money! IT IS THE ETHERNET CARD!!! SWITCH THE CARD AND IT WILL WORK!
I have a HP Elitebook 8770W, and was using the wired ethernet card. Kept having Youtube problems. I switched to wireless and it worked like a champ.
If you only have a wired card, either get a USB wired or wireless card and try it out!
Jamie Bass
Evansville First Nazarene
