Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Good evening. I would like to automate, perhaps with the "triggers" or other system, the airing of multitle. How can I do? Thank you!
ps watch the attached video
Originally Posted by: STADIORADIO  Good evening. I would like to automate, perhaps with the "triggers" or other system, the airing of multitle. How can I do? Thank you!
ps watch the attached video What video?
Datasource and autoadvance/loop it. Has been adressed before in this forum
perfect, tried and works very well! Just one thing: how do I get the list started when I start the overlay?
well then you will have to go to top of your list and loop through your data source with scripting and trigger the script with the OnTransitionIn trigger (is a possibility as there is no shortcut for starting to autrun/loop a data source)
well then you will have to go to top of your list/data source and loop through your data source with a scriptand trigger the scriptwith the OnTransitionIn trigger (is a possibility as there is no shortcut for starting to autrun/loop a data source) https://www.vmix.com/help22/PS There is even a script example in this forum to loop through a data source
