Joined: 3/7/2019(UTC) Posts: 9  Location: Medellin Thanks: 1 times
Hello!
Im looking to build a PC with extreme specs to have like 4-8 4K cameras.
I saw this capture card: "Osprey Raptor Series 1245 PCIe Capture Card with 4 x SDI Channels", anyone know if i can have 4 inputs at 4K resolution in vMix with this graphic card? or if you have one to recommend to me?
Those are the specs of the pc-build:
License vMix 4K Motherboard GIGABYTE X299-WU8 LGA 2066 Intel X299 Graphics Card GEFORCE RTX 2080 Ti Case Cooler Master MasterCase Pro 5 Modular Mid Tower Case HDD Samsung 960 EVO NVMe M.2 1TB SSD Samsung 860 EVO Series 2.5" 2TB Seagate BarraCuda 8TB PSU EVGA SuperNOVA 1300 G2 120-G2-1300-XR 80+ GOLD Capture Card 2X Osprey Raptor Series 1245 PCIe Capture Card with 4 x SDI Channels 1X Blackmagic Design DeckLink Quad 2 (8 channels on vMix to other inputs like pc, and outputs for LED external displays) CPU Intel Core i9 7940X + Cooler Master MasterLiquid Pro 240 Liquid CPU Cooler RAM 32GB (4x8GB) DDR4 Operating System Windows 10 Pro
Joined: 4/15/2018(UTC) Posts: 64  Location: Spain Thanks: 6 times Was thanked: 19 time(s) in 13 post(s)
Now blackmagic 8k can capture 4x sdi. Maybe someone can test compatibility.
Vmix only recommend 4x 4k inputs @ 30fps.
Maybe 4x 4k@60 is possible... but 8?, i think 8 is not possible.
Actually i only need 3 inputs at 4K@60... but im thinking to the future i will need more inputs at 4K resolution 60 frames.
