Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Request: OnDataChange trigger.
This has been requested before and alternative solutions have been offered – if you understand XAML etc, however I still think there is a strong case for considering this to help make it work in a simple way.
I have a Google-Sheets document, which I would like to use to trigger events in vMix. I don’t necessarily want it to trigger title displays, however, using a dummy title to receive the data and then trigger something else, would be very useful.
If the trigger could apply to a change in any element of the title it was connected with, that would be perfect, as I could then use a change of data in the spreadsheet to make something happen in vMix.
Many thanks, Giles.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 we could do so much with it.
We would use it to let us know when a new car class is racing and it would but a splash title up for us.
Also we could tag each class
we could stop start record and have the classes blocked off
and when the scores come in they could go up automatically and clear off screen as sometime we can't check if they've changed to the new ones if you put them up too quickly after a run
and maybe in future when a car passes a point on track we get elapsed time data so you could say when that changes to new data cut to the next shot, or something like when the race is over, return to a safe shot
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
+1
It is possible on fields in a GT Title, and it would be awesome if the same functionality was also available as a trigger for the input itself.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Joined: 5/24/2018(UTC) Posts: 20   Location: Worthing
Ok, this is what I want, please. +1 for OnDataChange trigger
+1
We use a footy scoreboard, we can change the score via keyboard shortcut - which can then trigger an Overlay, but when using an Excel Sheet (for the scoreboard) via Data Sources, vMix doesn't give you the option of Triggering that same Overlay when the score changes.
Please bring into the vMix.
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Joined: 12/3/2013(UTC) Posts: 123   Location: Arizona Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
+1 - a very important new feature.
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
