vierzwozwomedia
#1 Posted : Tuesday, March 5, 2019 5:51:26 PM(UTC)
vierzwozwomedia
Germany
Hello there,
i have currently a litlle issue with my NDI workflow.
The sitation is as flows:
I will use a Pepwave Br1 Max Router in my streaming rig for internal routing and controlling my streams. Usually my setup i build on a conferenz center or somewhere else. Which means i will habe a routing bevor my router.
The problem is that pc that are not direcly connecteted to my router are not reaching the NDI stream.
Is there something i need to pass throut with my router?
kevev
#2 Posted : Wednesday, March 6, 2019 4:24:00 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
I would use a dumb switch. Routers can be confusing.
mavik
#3 Posted : Wednesday, March 6, 2019 6:08:11 AM(UTC)
mavik
Make sure the router or bridge supports IGMP snooping.
Make sure only 0.0.0.0/0 is routed to the Pepwave
I will do a live stream on youtube talking about network and routing for streaming 03/07/19
