Feature Requests
Video Replay + Xbox Controller
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Hallo,
is it possible to give the Xbox controller the function to control the Video Replay
on the Controller
Press RT - go forward Press LT - go Back
Press RT + X -Fast forward Press LT + X -Fast Back
if it is at the moment possible how i cn configure it if not PLEAS import ist to VMIX !!!!!!
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
Yes!
Have you tried plugging it in and then looking at shortcuts?
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Barney Box Lane
Although the X Box Controller will work, it likely will not work in exactly the manner asked about. Each button and/or joystick position can only be assigned to a specific shortcut function and as such cannot be used in tandem with another (i.e. modifiers, which is another feature request) The Right and Left buttons could be assigned to play forwards and backwards and the X button to a play speed but they won't need to be pressed together, and then of course, you'd need another button to "undo" the speed you've just chosen or rather, choose another speed. I'd have to play around with it again, but I am pretty sure that is what I've had to do with my Shuttle Pro.
Feature Requests
