zhaixz
#1 Posted : Thursday, February 28, 2019 9:26:09 PM(UTC)
zhaixz
Looking at the picture I had 4 color modules.
I changed somethings in the yellow module like that
It should have been as same as the original, But look that
How could that be
#2 Posted : Thursday, February 28, 2019 9:43:08 PM(UTC)
so you are doing a multiview and then zoom.pan and crop on of the items ?
Zoom X 2 ??
Pan X 1
Crop X2 960 ??
Looks more like a feature
zhaixz on 2/28/2019(UTC)
zhaixz
#3 Posted : Thursday, February 28, 2019 10:00:02 PM(UTC)
zhaixz
Zoom X 2 ??
Pan X 1
Crop X2 960 ??
Yes, I am doing a multiview, it should be the same size as the original.
why???
#4 Posted : Thursday, February 28, 2019 10:03:21 PM(UTC)
Why would it have to be the same , you cropped only one side ,zoomed on side
I dont even believe zooming is exact by the numbers ie 2 isnt double
And curious minds want to know why even do this (this way)?
BTW hard to notice this way but even the vertical size isnt exactly the same the way you adjusted the sizes
zhaixz
#5 Posted : Thursday, February 28, 2019 10:42:04 PM(UTC)
zhaixz
if I replace Crop X2 with Crop x1, that would not be the case.
the zooming is exact by the numbers and ie 2 is double
zhaixz
#6 Posted : Thursday, February 28, 2019 10:54:03 PM(UTC)
zhaixz
I need to crop part of image or video and zoom it like this
#7 Posted : Friday, March 1, 2019 1:57:46 AM(UTC)
@ zhaixz
I don't think it's a bug, just the way vMix works with 3D in 2D space (xyz positioning with zoom).
This can be very tricky, especially if using MultiViews of MultiViews (layers are not pre-rendered so effects do not necessarily work as expected)
Why not simply adjust the "position" of the Overlay of the Input MultiView instead of the original Image or Input?
(again, this won't work on a MultiView of a MultiView as the layers are not pre-rendered, so not a bug, just the way it works)
