GT
Slow performance of GT Title in vMix - stutter and increased render time
I'm running vMix on a Mac Pro 2013 with Bootcamp. It is a 6 core Xeon processor with D500 AMD FirePro cards, 32GB Ram, 15+GB free space on the 50GB Windows Partition.
So far, it has been a mostly smooth experience through the 3-4 years of use.
Since the last update (no longer free), the performance of vMix has taken a turn for the worse. Namely the GT Title I wanted to create for a scoreboard.
The performance of vmix crashes any time I try to run the GT title as a multiview item for an input. It looks and works OK in GT Title Advanced creator, it also works great if I use the image sequence as a "stinger" multiview element, just not as a GT Title. The render time escalates from the normal 3-8ms to 1300-1900 ms and the mouse freezes during this time as well. The title has been seen as stopping half way through its animation, never completing the sequence. Please note this is a test setup with just static images as sources, I dread to think what the performance will be like when I plug the 8 cameras we use on a normal basis, with adverts and stats and so on...
Any ideas what set of settings I should use to make the GT Titles work? Any help would be greatly appreciated...
By the way, I also have a 2016 MSI Stealth laptop with a Geforce GTX970 Nvidia graphics card, the same title is smooth as butter...
Many thanks, George
Hi George, I havia the sabe problem, Do You got it solve?
Originally Posted by: Evertonav  Hi George, I havia the sabe problem, Do You got it solve?
Answer is right in the question: MAC = problem WindowsPC = smooth as butter (Then again this was 2 years ago!
GT
