Joined: 6/12/2015(UTC) Posts: 3 Location: South Africa
Hi Folks I need some help on choosing new configuration.
I'm thinking about the new decklink quad with 8 inputs, does this mean it can take 8 camera's and will VMix support this ?
Does anyone know if this will fit into an expansion case? That way I can move it between laptop and desktop if I need.
If there are alternatives to the decklink that might be good also Thanks for any help here
Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
Hi! Using Decklink Quad 2 more than year. Works fine. Yes you can use all 8 inputs to set up as inputs or outputs in any combination. 8-0, 7-1, 6-2 and so on. But first after installing it's works like Quad 1. Only 4 inputs or outputs. You need change setting at BM Desktop video program.
About using with expansion, can't say. Using only with Desktop.
With vMix works perfectly. Win10, latest updates. vMix 22? also works with 21
