amsudeen
#1 Posted : Saturday, October 5, 2013 10:36:12 PM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
VMIX 11.0.0.20 LIST QTA FILE PLAY CONTINUOUSLY AND SAME TIME PLAY BLANK SCREEN.
THANKU
#2 Posted : Saturday, October 5, 2013 11:46:06 PM(UTC)
Please do not post in all caps!
Can you provide more information?
It is difficult to tell what you mean.
amsudeen
#3 Posted : Sunday, October 6, 2013 9:51:51 AM(UTC)
amsudeen
add input\select list\load 20 qta (alpha) files load.
i don't use play button. but, it's play automatic and continuously.
the same time the play only blank screen. not show the video.
i using vmix from version 8. i not face this type of problem up to last version.
after i unstall version 11. i install again version 10 it's work fine.
i try my same pc.
thanku.
#4 Posted : Sunday, October 6, 2013 11:04:05 AM(UTC)
Thankyou, I have found the blank issue when playing back QuickTime files in the List and will fix it soon.
I can't see the automatic playing problem though, could you explain that in more detail?
As a test I added three quicktime vidoes and they did not start until I clicked Play.
amsudeen
#5 Posted : Tuesday, October 8, 2013 2:42:59 AM(UTC)
amsudeen
i try many time, automatic playing problem found.
#6 Posted : Tuesday, October 8, 2013 3:39:35 AM(UTC)
Please describe step by step so I can re-create the playing problem.
#7 Posted : Tuesday, October 8, 2013 6:04:06 AM(UTC)
Playback of quicktime files in List in vMix 11 has been fixed:
http://forums.vmix.com.a...osts&m=6330#post6330
amsudeen
#8 Posted : Tuesday, October 8, 2013 8:45:02 AM(UTC)
amsudeen
in vmix 11.0.0.25
press play button, play continuously all files.
version 10.0.0.59 work fine
i try my same pc.
thanku.
#9 Posted : Tuesday, October 8, 2013 8:51:53 AM(UTC)
This is by design, when you click play, all the videos in the list will play one by one.
If you only want one to play, add it as a separate video.
The stopping after each quicktime video in vMix 10 was a bug.
amsudeen
#10 Posted : Tuesday, October 8, 2013 9:58:41 AM(UTC)
amsudeen
DEAR MARTIN,
this is by design accepted. we don't know vMix 10 have a bug. we create more then 400 qta (alpha)in one list ( Transistion FX ) files for using via stringer1.
this is work very good Transistion FX for us. can have give any solution.
the same time ( version 11 ) we can't add separate 400 files. vmix is hang.
thanku
#11 Posted : Tuesday, October 8, 2013 10:17:02 AM(UTC)
vMix 11 needs to scan all of videos to find out its duration, so it will take as bit longer but if you wait
a minute or so they should all load.
Why do you need to load 400 files? Perhaps there is a simpler solution.
amsudeen
#12 Posted : Saturday, October 12, 2013 11:42:16 PM(UTC)
amsudeen
Dear martin,
please check this link :
you say, vmix version 9 and version 10 the list file play bug.
but, this bug we are using many transition effects easily. and play list qta files support via stringer1.
like this effects we are created more then 900 effects. now version 11 list files play continuously . so our all transition effects can't used.
please, help us we want use our all effects like this
give us better solution.
we are created more effects and plan to sale vmix hd software.
( forward 4 minutes then play, you can see our effort and effects.)
in feature we are in re seller for india.
thanku
