jdrwor
#1 Posted : Friday, October 4, 2013 5:21:52 PM(UTC)
jdrwor
When I try streaming I am not getting any output showing up in the text box. I have verified that the stream is actually running. When I press the Stop button a vMix Error box pops up that says "Could not read console buffer" and in the text box says "Streaming_StartStop".
The weird thing is it only happens on my development PC. The same version of vMix streams with proper output on my test PC. Both PCs are running Windows 7. I assume it's something installed on the Dev box that is causing the issue but I'm not sure what. Has anyone else seen something like this?
Here's a snapshot of the error.
http://picpaste.com/vmix...uffer_error-ZDU0aQpW.png
jdrwor
#2 Posted : Saturday, October 5, 2013 1:44:25 PM(UTC)
jdrwor
I found out what the issue was. On my dev machine I had changed the default size of the command prompt window to be much larger. When I set the default size back to standard it started working again. The streaming output was displayed properly and no error appeared.
#3 Posted : Sunday, October 6, 2013 12:08:53 PM(UTC)
Thanks for the report, I will test this out and fix it for the final vMix 11 release.
#4 Posted : Sunday, October 6, 2013 12:18:34 PM(UTC)
What command prompt settings did you choose that causes the error?
I can't seem to replicate the issue.
