Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi I have an XML document with a large number of fields. I want to select a block of data using 'position' eg <?xml version="1.0" encoding="UTF-8"?> <Main> <Data> <Field no="1">Name1</Field> <Field no="2">Name2</Field> ..... ..... </Data? </Main> I used //Field[5 <= position() and position() <= 10] which gives me a result using https://www.freeformatte...th-tester.html#ad-output<Field no="1">Name1</Field> <Field no="2">Name2</Field> <Field no="3">Name3</Field> <Field no="4">Name4</Field> <Field no="5">Name5</Field> ok good, so i plugged that into vMixx and get |no|#text |5|name1 |6|name2 |7|name3 |8|name4 |9|name5 So I don't want the "no" column just the name data. [EDIT it's returning the attribute 'no' ? ] I tried //Field[position() <= 5 and position() <= 10]/text() in https://www.freeformatte...th-tester.html#ad-output and it returns name1 name2 name3 name4 name5 Plug that into Xpath in Data Sources and I get an "ERROR: Object reference not set to an instance of an object" Sorta stumped, has anyone some advice? Regards Ash
Rank:: Advanced Member
I am not getting the same based on the post BUT
try this: //Field [position() >=2 and position() <= 10]
If that doesn't work try this //Field [position() >=1 and position() <= 10]
Originally Posted by: kjones9999  I am not getting the same based on the post BUT
If that doesn't work try this //Field [position() >=1 and position() <= 10] Thanks kjones9999, tried both and it still returns the "no" attribute as a column. Seems I am getting an error when ever I try to use the /text() to extrat the inner text value of "Field", maybe text() is not installed in XML version in vMix or I am not understanding the usage correctly In any case I have used a work around in vMix Data Source by assigning the Column for each text place holder in the GT title and that works. Incidently I do not have control over the XML file as that is generated from a 3rd party app from the scoreboard source. Ash
I see-- you must be leaving something out of the feed because I posted what you had and it worked in the validator.
Actually I loaded in to vmix and that first row is treated as a column label and vmix does not use it.
 1 user thanked kjones9999 for this useful post.
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Based on the XML shown, using //Field by itself should work just fine or //Field[5 <= position() and position() <= 10] There will be a column for the attribute no, but you can ignore that and just assign the title fields to the #Text column without issue..
Martin vMix
Martin vMix Hi Martin Thanks for the input and your suggestion is exactly what I did. Regards Ash
