Feature Requests
Ability to recover from a thunderbolt disconnect
Forum Rank:: Advanced Member
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
In vMix, a thunderbolt disconnect - caused by accidentally unplugging the cable or even just a potential driver bug - is catastrophic because vMix needs to be restarted to be able to recognize and use the input again. This means you would have to stop recording and streaming.
Both OBS (version 21.1.0 tested) and Blackmagic Media Express (version 3.5.5 tested) handle unplugging and reconnecting very well and do not need to be restarted, so my hope was that this robustness could be built into vMix 22.
In OBS the thunderbolt input will be refreshed and recovered automatically after plugging in the thunderbolt device again. This is nice, but even having the ability to manually right-click source refresh/reset would be a big improvement. The important thing is the ability to regain access to the input without closing/opening vMix.
 1 user thanked niemi for this useful post.
Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
That would be catastrophic! Yes, please add that ability. I use a Decklink Duo 2 via Thunderbolt 3, and haven't had an issue yet, thankfully.
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
+1 We've had this problem many times during preparations, but luckily enough never in live situations although I am always afraid it will happen. Thought it was a Windows problem, but if OBS and BMME can handle it, hopefully vMix can too.
 2 users thanked richardgatarski for this useful post.
Joined: 10/22/2018(UTC) Posts: 4  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 579 times Was thanked: 202 time(s) in 168 post(s)
If this was fixed in vMix, would it apply to vMix 22 only, or also 21?
Joined: 10/17/2018(UTC) Posts: 22  Location: Rawang Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Joined: 11/1/2018(UTC) Posts: 21   Location: NY Thanks: 4 times
I wonder, if after disconnect, you deleted and recreated the inputs, would that work? I don't have my T3 box yet to try. Maybe play a 2 minute break to give you time. You could also use a separate encoder like from Teradek or an OBS PC to handle your stream. Not the best solution, as the stream may go black, but better than having to stop the stream and restart it and get people to rejoin imho.
I think this illustrates how unfortunate the TB3 connector is. It's like HDMI. Just not well considered for professional use.
That's why BNC and Ethernet are locking connectors. Convenience always has a cost, often in reliability.
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Joined: 4/23/2017(UTC) Posts: 1,433  Location: Germany Thanks: 3 times Was thanked: 191 time(s) in 171 post(s)
I even have the same problem with my Av.IO USB3 capture card. Once it's unplugged it is lost in vMix.
Originally Posted by: mjgraves  I think this illustrates how unfortunate the TB3 connector is. It's like HDMI. Just not well considered for professional use. That's why BNC and Ethernet are locking connectors. Convenience always has a cost, often in reliability. As a matter of fact, there are locking connectors for Thunderbolt, for example from Sonnet. But the point here is "if" the Thunderbolt disconnects, it would be great if it just could be connected again without having to reboot the PC. Compare you can disconnect SDI or Ethernet, that will not lock the system.
Originally Posted by: dedlinemedia  I wonder, if after disconnect, you deleted and recreated the inputs, would that work? I don't have my T3 box yet to try. Maybe play a 2 minute break to give you time. You could also use a separate encoder like from Teradek or an OBS PC to handle your stream. Not the best solution, as the stream may go black, but better than having to stop the stream and restart it and get people to rejoin imho. No, unfortunately not. You will need to exit vMix completely and open it again. Most Teradeks encoders will lose sync whenever you stop the external output in vMix which will cause the stream to stop as well. Some of the newer encoders, for instance, the Teradek CUBE 655, have a sync generator that will keep the stream running with a pattern/test signal while the input recovers.
Originally Posted by: richardgatarski  As a matter of fact, there are locking connectors for Thunderbolt, for example from Sonnet. But those are proprietary. They require that the host device have the mating threaded hole. That's fine for a Sonnet box or card, it won't be there on any laptop. The fact they are offered further illustrates the faulty design of TB3 for professional applications.
Joined: 2/9/2013(UTC) Posts: 264 Location: Katy, Texas
+1 and also have the same capability for USB devices such as capture and midi
Joined: 3/7/2012(UTC) Posts: 503  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
will do some tests. but isn't part of the problem the tb3 connection in windows itself. how dies bm handle disconnects?
if there is no problem at that level it would just require vmix to reload the preset ?!
for me all inputs hang on that connection so rec is lost anyway... stream is on a different machine...
stefan
just did that now - was testing v22 - disconnected tb3 - vmix gives warning rec is stopped, actually the ext connection was. rec continues. replugged, stopped rec, restarted vmix reloaded profile: running....
I think that's not too bad!
but you have to restart vmix again and load a profile or last...
keep an eye on that because your rec could be lost...
advantage is this is a fail proof restart of vmix, which I would prefer...
will watch this topic to see what Magic Martin can do... stefan
 1 user thanked h2video.nl for this useful post.
Feature Requests
