ben1000
#1 Posted : Wednesday, February 20, 2019 3:18:36 AM(UTC)
ben1000
Howdy...
I think I've found a bug with the Virtual PTZ control when using a joystick in V22...
Let's say I have a 4K camera setup, and a virtual input copy that I want to use to 'punch in' on the 4K....
I can activate Virtual PTZ on the 2nd input, and use the little onscreen controls to zoom in and pan around... All good so far...
However, I have my Xbox Joystick setup to do the PTZ controls on whatever is in 'preview'...
If I have the main input in preview, the Xbox joystick works just fine...
If, however, I put the 2nd Virtual Input in preview, the joystick STILL zooms the main input #1. Not the virtual input...
I can still zoom the virtual input by opening the settings windows and using the PTZ controls in there, but I can't get the joystick to adjust the virtual input, even when it's in preview...
Can you confirm this for me? I don't think I'm doing anything wrong, but I can't figure out how to adjust the Virtual PTZ controls via the Xbox joystick when it's a virtual input that's in preview...
Hope that's clear! Let me know your thoughts...
Best,
Ben
#2 Posted : Wednesday, February 20, 2019 12:55:54 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
That is correct, PTZ control is only possible on the input connected to the provider. The virtual inputs are set to a fixed position only and can't be changed
using the controller.
ben1000
#3 Posted : Thursday, February 21, 2019 8:49:36 AM(UTC)
ben1000
To clarify:
PTZ control IS available on virtual inputs, but not through the joystick... Must be done through the setting screen...
Hopefully this can be added in the future, as it would be super-useful! :)
Best,
Ben
#4 Posted : Thursday, February 21, 2019 12:20:22 PM(UTC)
Hi Ben,
That is not correct, unless manually connecting again on these virtual inputs, which will lead to unexpected behavior
as these virtual inputs are designed to be a preset at a fixed position.
kevev
#5 Posted : Wednesday, February 27, 2019 8:09:27 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Well that sucks. My plan was to perform vurtual ptz on a low budget 4k setup.
#6 Posted : Wednesday, February 27, 2019 11:58:39 AM(UTC)
I think there may be some confusion.
To confirm you can just joystick control on Virtual PTZ, you just need to make sure you assign the shortcuts
to the input that is connected to the Virtual PTZ, not any copies of that input.
kevev
#7 Posted : Wednesday, February 27, 2019 2:56:31 PM(UTC)
kevev
So how do we control virtual ptz on 3x 4k inputs?
#8 Posted : Wednesday, February 27, 2019 7:20:38 PM(UTC)
Connect to Virtual PTZ on each one, and when you want to adjust one with the joystick, place it in Preview.
kevev
#9 Posted : Thursday, February 28, 2019 1:52:30 AM(UTC)
kevev
OK that makes sense. Thank You.
One last question. Can we connect 3 joysticks to vMix and have each of them control 1 virtual ptz each?
