Thremir
#1 Posted : Sunday, September 29, 2013 8:50:04 AM(UTC)
Thremir
Hello!
Was working on a project and making a 3rd party control-panel when I noticed that the stinger aren't working like they should?
I set them in the overlay menu with video, which works perfectly, but when set as shortcut "A" the stinger completely ignores the "input" box that were set in the same shortcut menu, it only goes to the preview.
Only me experiencing this? Tried on 3 different computers.
The web API doesn't work either (api/?Function=Stinger1&Input=3, it ignores the "Input=3" parameter)
Any help would be appreciated!
#2 Posted : Sunday, September 29, 2013 9:44:44 AM(UTC)
For Stinger1 and Stinger2 the Input is specified directly in the Overlay Settings window.
If you want to specify an input for a shortcut or API you will need to use the 1,2,3 or 4 overlay channel instead.
Thremir
#3 Posted : Sunday, September 29, 2013 10:23:27 AM(UTC)
Thremir
But to select which input to switch to after the stinger, what do I do?
Thanks for replying so quickly :)
#4 Posted : Sunday, September 29, 2013 10:34:16 AM(UTC)
Sorry, I misread your question.
To change the preview requires a separate function first, "PreviewInput" in this case.
