Vmix and stream live in Skype for business Meeting Broadcast
How Vmix can live stream in Skype Business Meeting Broadcast ?
Best regard,
Pahb
 1 user thanked phab for this useful post.
Joined: 4/7/2016(UTC) Posts: 20  Was thanked: 1 time(s) in 1 post(s)
By using Newtek Transmit or a USB capture device like Blackmagic Web Presenter or AJA U-Tap.
Best Jan
Hi usmedia, Sorry I do not understand how you make skype stream with your solutions? Maybe a solution with Microsoft Stream, but it pays... ;) https://youtu.be/XWvnKmQPw8gBest, Phab
The vMix "external" functions emulates a webcam. So if you have SfB client on your vMix host you can simply select vMix Video as the camera in SfB.
Alternatively, you might want to run SfB on a different system. In that case, your run Newtek Virtual Input on that system.It will let you use the NDI program signal from vMix as a source for the SfB client, or any other client that expects a webcam as a source.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: mjgraves  The vMix "external" functions emulates a webcam. So if you have SfB client on your vMix host you can simply select vMix Video as the camera in SfB.
Alternatively, you might want to run SfB on a different system. In that case, your run Newtek Virtual Input on that system.It will let you use the NDI program signal from vMix as a source for the SfB client, or any other client that expects a webcam as a source. We use this method everyday. Works with Teams and Stream Live also very well. Steve
