RandoM
#1 Posted : Tuesday, February 12, 2019 6:57:43 AM(UTC)
RandoM
Estonia
Awesome work on the title designer, really-really loving it!
It would benefit for my use from two things:
a) PNG image sequence import, to be able to transform some of After Effects projects to the new title format to natively work with vMix, As I'm really loving the GPU usage and ability to time text fields
b) PNG image sequence export to be able to use the same designs on hardware switchers. I totally understand that this may not be the first priority, considering what the GT designer is meant for, but it would be really helpful for some of us. Even if this would be added as an recoring method in vMix Pro and 4K edition itself, that would be awesome!
chrisis
#2 Posted : Friday, February 15, 2019 6:46:44 AM(UTC)
chrisis
You can already import PNG sequences. Just add an Image and then add the first image in the PNG sequence when you select file.
To activate the animation you need to select ImageSequence from the animations tab.
thanks 2 users thanked chrisis for this useful post.
blue28 on 2/20/2019(UTC), DannyGudkov on 3/15/2019(UTC)
mark
#3 Posted : Tuesday, September 6, 2022 11:10:29 PM(UTC)
mark
Rank:: Advanced Member
Would love this feature too!
Take the recording of a live event and use the ability to use the same graphics that was used on the live event for the edited project.
Currently I have to build graphics in GT Designer for live…
Then rebuild them again for the edit!!
Export ability to a png sequence would be really really good!
