I am fairly new to vMix and just tried add a midi file (FILENAME.MID) as an input. It seemed to add just fine, but there is no audio, that is, it's not working in vMix. Any ideas as to how to add a midi file? BTW, I can create an MP3 as an input and that works as expected in vMix and the midi file can play if it's opened in Windows (Win 7, 64 bit), but just not in vMix.
you can use a good audio conversion app and convert it as a file that works in vMix...There are a few goog free ones out there.....can;t remember the one I use, as I am not near my editor at the moment
