Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi!
Anyone has tested the TP-LINK TL-R470T+ router? I have find that in some websites people talk about "bonding". I know the difference between balance and bond, just want to know your experiences.
Regards
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
hello guztavo, I've purchased one TL-R470T+ 4 year ago for the same thing. At that time in my region there was only 3g for the mobile connection. During a job I saw a technician who used it for bonding. Also I know the difference between bonding and balancing and for this I did not believe how to realize bonding without an accomplice on the other side who rebuilt the packets. I documented and found feedback from users who showed how to set up bonding with the R470T+. Finally I bought the router and tested the bonding between a line adsl (Upload 800kbps max) and a connection HSUPA mobile (Upload 1500kbps max) .... it worked! total upload average up to 2300kbps. I still can not explain how to do it. Used the system for some streaming then abandoned in favor of 4G. I still own the router if you need me to do some tests, let me know Giulio.
Originally Posted by: giulliu  hello guztavo, I've purchased one TL-R470T+ 4 year ago for the same thing. At that time in my region there was only 3g for the mobile connection. During a job I saw a technician who used it for bonding. Also I know the difference between bonding and balancing and for this I did not believe how to realize bonding without an accomplice on the other side who rebuilt the packets. I documented and found feedback from users who showed how to set up bonding with the R470T+. Finally I bought the router and tested the bonding between a line adsl (Upload 800kbps max) and a connection HSUPA mobile (Upload 1500kbps max) .... it worked! total upload average up to 2300kbps. I still can not explain how to do it. Used the system for some streaming then abandoned in favor of 4G. I still own the router if you need me to do some tests, let me know Giulio. Dear Giulliu, Thanks for answering. I will buy one... hope to have it for next show on sunday. Best regards.
