Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi! The last sunday started a new season of soccer, and i found some issues on our setup. For some reason, the cam 1 appears to drop some frames (check during the match here: , the image is not fluid). Camera 1 (with issues): HDMI to SDI over conversor, to BMD Mini Recorder Camera 2: SDI to BMD Mini Recorder Camera 3: HDMI to NDI (Connect Spark) over ethernet cable The strange is that the issue only appears on cam1, and two hours later, same camera direct over SDI works fine. The HDMI to SDI conversor can do this? The other strange thing is that vMix UI freezes twice on the first 10 minutes of recording and streaming while playing a mp4 file (from a list, that works fine, used a lot of times before), and that froze was aired, but audio of line input still working and aired. What can be the issue? Thanks!! Sys: vMix 21.0.0.59
