Joined: 10/20/2017(UTC) Posts: 23  Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
How can I do the following with vimix? 1. I have a ndi graphic input with alpha as overlay 2. I am switching three cameras behind that graphic window see attached picture 3. The Camera picture has to be reduced in size to fit in the graphic window So everything set for Display 2 Display 1 And here is my question: How can I output my video on Display1 output in the original size and without graphic? (the graphic part I understand) In a traditional mixer I would switch the cameras in ME1 and apply the size effect plus graphic on ME2 The output of ME1 would be my Display 1 and output of ME2 would be Display 2. I know that Vimix does not work like this, but I can not figure out how to get rid of the "size effect" on Display 1. The picture shows my screen 1  graphic.jpg (244kb) downloaded 0 time(s).
Originally Posted by: narcus  How can I do the following with vimix? 1. I have a ndi graphic input with alpha as overlay 2. I am switching three cameras behind that graphic window see attached picture 3. The Camera picture has to be reduced in size to fit in the graphic window So everything set for Display 2 Display 1 And here is my question: How can I output my video on Display1 output in the original size and without graphic? (the graphic part I understand) In a traditional mixer I would switch the cameras in ME1 and apply the size effect plus graphic on ME2 The output of ME1 would be my Display 1 and output of ME2 would be Display 2. I know that Vimix does not work like this, but I can not figure out how to get rid of the "size effect" on Display 1. The picture shows my screen 1  graphic.jpg (244kb) downloaded 0 time(s). You'd most likely have to have a double set of shortcuts for cutting cameras. CAM 1 shortcut cuts camera 1, and changes the output 2 to the camera feed, CAM2 shortcut cuts output 2 to cam 2 feed.
Ok thanks that sounds quite promising ! Can one apply two shortcuts to one button with x-keys ?
Originally Posted by: narcus  Ok thanks that sounds quite promising ! Can one apply two shortcuts to one button with x-keys ? i've done 5-10 shortcuts with one button before! just add it like you add any normal button, it will be in red text, indicating you already used that button (but that's what you want anyway!)
 1 user thanked spencerm24 for this useful post.
