BUG - Green Screen/Chroma Reset
Green screens are reset when a monitor is unplugged from vmix while it's running. The setting still shows it as checked but it is not in effect.
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi, We are unable to replicate this behaviour unfortunately. The chroma key is maintained when unplugging a monitor here. After the problem occurs, go to Settings -> About and click Send Support Report in vMix and drop us an email at info@vmix.com.auThanks, Martin vMix
We unplugged a monitor, plugged in a projector on a different port(same resolution and refresh rate, dvi monitor to display port projector-display port male to female HDMI) GTX 1080 ti. We enabled/disabled fullscreen mode several times to make sure the full screen went to each of the 2 projectors without restarting vmix/pc. We also had an HDMI capture card whose green screen was checked but not working when we made this change.
