Charssay
#1 Posted : Thursday, September 26, 2013 3:04:01 AM(UTC)
Charssay
Dear martin,
One or two question :
I advice a friend to use Vmix to manage its live feed and was ok for that.
He ask me that he wanted to use HD and SD on the same time.
But the cost for HD basic and its unit don't fit realy for him and ask me this question that I'm sharing with you
The SD plan seems good and complete, the Basic HD is good but limited and the HD plan seems to be more than the double of SD plan even of it is the best standard choice anyone could take.
Then he ask me :
-why do not make or upgrade the Basic HD with 4 overlays instead of one and increase its price, so that this plan could be more complete, knowing that you do have a good reason to propose these four plan like you did.
-Its possible in the Basic HD plan to use also SD camera if you do not have HD camera ?
Thanks for your feedback
Rgds
C.
#2 Posted : Thursday, September 26, 2013 3:12:51 AM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
This has been discussed on these forums a few times over the past couple of years.
vMix HD is priced at a 1/3rd of the nearest competing solution and as such is extremely good value.
The Basic HD version is there for users starting out, but it is expected that they will eventually
move to HD which is why things are priced the way they are.
Charssay
#3 Posted : Thursday, September 26, 2013 11:00:33 AM(UTC)
Charssay
Ah. OK
Seetha Ramaiah Velicheti
#4 Posted : Thursday, July 25, 2024 3:32:25 AM(UTC)
India
#5 Posted : Thursday, July 25, 2024 3:34:23 AM(UTC)
India
Sir, in vMix Basic HD Plan can I live-stream at 1920x1080p? Is there option to that effect?
