azanisarri
#1 Posted : Friday, January 25, 2019 11:13:12 AM(UTC)
azanisarri
Malaysia
Hi, how can we import the animation logo in 2d or 3d in GT Tittle template. And can we import the logo in the ticker? Thank You
NHT
#2 Posted : Sunday, January 27, 2019 2:59:07 AM(UTC)
NHT
You can't add an image to a ticker.
To add an image animation you need to render the original video out of your edit software as a PNG image sequence, or a video with an alpha channel.
If you output the video with the alpha channel you can use vMix video tools to create an image sequence.
Then put the image sequence in a folder and add the first image of the sequence to your project, then select 'image sequence loop' in the animation section.
thanks 2 users thanked NHT for this useful post.
azanisarri on 1/27/2019(UTC), bluesgeek on 10/23/2019(UTC)
