matteoarrigone
#1 Posted : Thursday, January 17, 2019 6:56:40 AM(UTC)
matteoarrigone
I'm planning to buy a new pc for vmix. I would like to use intel core i9 9900k with Aourus Z390 Master and rtx2080 gigabyte. I plan to buy also 250 gb nvme ssd for the OS and another 1 tb ssd for media. About the Ram I was thinking about 32gb (2x16gb) at 3200 MHz.
I would use this system with a Blackmagic decklink quad 2 with 6 inputs and 2 outputs. I will use 6 cameras in 1080 50i, 2 calls, 2 desktop captures. all inputs sent from vmix via ndi and 2 outputs sent via ndi. 2 external in 1080 50i, recording in ffmpeg at 6mbts and streaming to Facebook in 720.
At the moment I'm using a pc with i7 4th gen and GTX 1050 but with 2 call, external, recordings and streaming it always has a problem with dropped frames due to CPU overload.
Can you tell me if this setup will work properly and, in case, tell me what to modify.
Thanks a lot
Matteo.
Ps. I saw the reference systems in Vmix website but they uses GTX gpu and intel 8th generation cpu.
ask
#2 Posted : Thursday, January 17, 2019 4:40:31 PM(UTC)
ask
Check out the latest vMix Funtime Live Show for Martin's comments re RTX2080
ProSonas
#3 Posted : Thursday, January 17, 2019 7:43:07 PM(UTC)
ProSonas
Denmark
