Barney Box Lane
#1 Posted : Monday, January 14, 2019 10:30:06 AM(UTC)
Barney Box Lane
Hi, this happened a while ago but I can't for the life of me remember how I rectified it.
I've deleted all the replay files and docs so it's just and empty folder and the Instant Replay has defaulted to 1080p but is also greyed out even after I do delete all, I've also tried a 1080 sample input to get it ammended and it still stays greyed out after deleting all. Sorry if it's an easy one and thank you in advance )
Kelvin
#2 Posted : Monday, January 14, 2019 11:36:36 AM(UTC)
Kelvin
Try deleting the entire folder, not just the contents of the folder. Something like that work for me when I was trying the replay system a few years ago.
ask
#3 Posted : Monday, January 14, 2019 12:04:09 PM(UTC)
ask
Simply point the replay session to a new folder.
Barney Box Lane
#4 Posted : Tuesday, January 15, 2019 11:24:01 AM(UTC)
Barney Box Lane
Thanks guys the new folder thing didn't work but I'm sure it was something like that and I couldn't change the destination because it was greyed
found a super easy was of doing though, you just go to the txt document in the replay folder and find where it says the resolution and change it to the correct one
petervk
#5 Posted : Sunday, May 26, 2019 7:35:52 PM(UTC)
petervk
Same issue here trying to change the session folder and recording format.
Both are grayed out and I cannot change them.
This is quite annoying when you have to switch back and forth from PAL to NTSC from time to time.
Unfortunately I cannot find any file in the replay folder containing the word 'resolution'.
Could you please be more specific on the exact file name and the exact property name?
Peter.
