Joined: 12/18/2017(UTC) Posts: 3   Location: Jordan Thanks: 1 times
i have a Feature Request to make it possible to set the initial text size for example 22 and if the text is larger than the box , it will automatically change the text size to 21 or less depends on the text box size.
this Feature Request will help me very well , because some times the text in the database is larger than the box by 1 character , so the last character will be out of the design.
Joined: 12/27/2012(UTC) Posts: 5,441  Location: Belgium Thanks: 309 times Was thanked: 1001 time(s) in 828 post(s)
Already there in (upcomming) v22
