Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi We have been using vMix for over 4 years (collectively more) and this is the first time I have been caught out with the Output settings. See below. Is it possible to have a warning to the user on stream startup that the "1 Output" is set to something other than "Output" ? Regards Ash  Output 1 Preview.PNG (32kb) downloaded 2 time(s).
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
I think Output1 was fixed to Output as it should logically be, but many users requested for the ability to change this for some obscure reasons. Now if we have warnings for everything, it's hell. Maybe allowing to change Out1 setting should be in the "advanced settings" only in order to prevent from such issues you're having.
Guillaume
+1
Please implement this small addition. You could also top of vmix screen in red what output 1 is set on.
Cheers Gerry.
+1
Cheers Gerry.
