8 Pages«<34567>»
butcharuski
#81 Posted : Saturday, January 5, 2019 5:48:01 AM(UTC)
butcharuski
I am loving the GT Title Designer. Well done!
POSSIBLE TRIGGER ISSUE THOUGH:
I could be doing something wrong, but I can't seem to get the triggers to work on an input. More specifically, I am trying to reset and start a countdown timer when clicking on an input. I got it to work with shortcuts, but for my reasons I want to use triggers instead.
#82 Posted : Saturday, January 5, 2019 8:34:22 AM(UTC)
@ butcharuski
Clicking on an Input isn't necessarily a "triggerable" action.
What is your "Mouse Click Action"?
Input cog wheel ===> General ===> Mouse Click Action dropdown menu
(each Input can be different, but the default is "send to Preview" which wont trigger anything)
SHMD
#83 Posted : Saturday, January 5, 2019 10:28:01 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Possible Bug report that is a carry over from vMix21
When testing out the loudness meter Wave Dorrough plugin I noticed the window does not resize nor can you change the size when the layout format changes between hardware vertical and horizontal emulations.
I only happen to check tonight in vMix as a user asked about loudness meters, never noticed in the past as I use the industry standard waves WLM plugin to monitor loudness levels.
Here are some screen shots of the behavior and it is the same in vMix 21 and vMix22 Preview Release. I can not think of any other plugins that change layout like this so not sure it would have been caught in the past.
If you need anymore info just let me know.
Vuurmannetje
#84 Posted : Saturday, January 5, 2019 11:59:30 AM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
This was an issue before Vmix 22. The plugin window does not support dynamic size. Thats also why we cant do soundgrid server plugins.
shawntempesta
#85 Posted : Sunday, January 6, 2019 7:49:58 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
BUG ISSUE: Not sure if it is directly related to vMix 22...
Regarding vMix Social.
  • New GT designs are not updating (I will send another post to the design, but it will animate in without the update). The old XAML layouts ARE updating.
  • No images whatsoever are loading to vMix Social.
The second part is a bit more frustrating. The log reads as follows:
(DATE) - Error - ImageDownload (long string) - The remote server returned an error: (403) Forbidden.
(DATE) - Error - Send - (blank) - The remote server returned an error: (500) Internal Server Error (127 0 0 1 API call string here...)&SelectedName=FromPhoto.Source&Value=(another long string)
Only subtracting the long strings because it is nailing me for spam otherwise.
#86 Posted : Sunday, January 6, 2019 6:46:43 PM(UTC)
Was thanked: 4790 time(s) in 1644 post(s)
Are you running the latest beta with vMix Social 5.0.0.8?
Reason I ask is the error message posted is exactly what we fixed in the latest vMix Social update.
sinc747
#87 Posted : Monday, January 7, 2019 2:24:57 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Just noticing that when I save a preset, the overwrite confirmation window appears twice.
22.0.0.38
- Tom
smudge1977
#88 Posted : Monday, January 7, 2019 7:32:20 AM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
Where has instergram gone in vMix social?
Seems it has been replaced with Twitch - great having a new platform for Instergram should still be available?
ask
#89 Posted : Monday, January 7, 2019 8:41:48 AM(UTC)
ask
RizoWBD
#90 Posted : Monday, January 7, 2019 9:39:07 PM(UTC)
RizoWBD
There seems to be an issue when using GT animated titles and Data Sources.
When I change some input in a Data Source (Text file), the DataChangeIn triggered Animation works fine, but then the DataChangeOut Animation still shows the previous Data loaded. The new Data is then displayed after the end of the animations. It is a random issue ; sometimes the text loads fine, and sometimes it hangs with the old data.
22.0.0.38
#91 Posted : Monday, January 7, 2019 10:53:49 PM(UTC)
Are you able to send us an example template that does this?
One thing to consider is multiple data updates in between the time it takes to run the DataChangeIn and DataChangeOut
For example, if these animations take 5 seconds to complete, but there have been 4 changes to the data in 5 seconds
it won't run the animations 4 times, instead it will update the text with the latest data when it receives it, which may be
in the middle of an animation.
sbtv
#92 Posted: : Tuesday, January 8, 2019 8:12:20 AM(UTC)
sbtv
Originally Posted by: admin Go to Quoted Post
vMix Beta 22.0.0.38 Released
* Fixed vMix Video Codec blank frame issue in latest Magix Vegas and Adobe Premiere
I am running Vegas 16 build 352 (latest version) along with latest vMix. A video recorded with vMix Video Codec will import but there is only 1 second of audio followed by silence. The file does open correctly in Premiere.
shawntempesta
#93 Posted : Tuesday, January 8, 2019 5:44:42 PM(UTC)
shawntempesta
AH HA. Updated. Everything is great now. Dummy I am waiting for the update within the program.
jadk
#94 Posted : Tuesday, January 8, 2019 11:56:19 PM(UTC)
jadk
Virtual PTZ -> support for 360 equirectangular video input as regular video output with presets, or 360 video in vset with presets would be great
ask
#95 Posted : Monday, January 14, 2019 10:09:09 AM(UTC)
ask
GT Title designer issue (or id10t issue): Setting up a simple credit roll that scrolls vertically. Have set a Text Box>set Centred>Animations>Set Scroll> Set Scroll Direction>Set Duration=10 sec>Save.
Result = OK
Change Scroll Duration manually=20 sec>Save.
Result =2 sec
Can you check please?
It would be nice to have a greater number of Duration options in the drop-down list.
Cheers
Andrew
vmixsupport
#96 Posted : Monday, January 14, 2019 11:01:44 AM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 160 time(s) in 73 post(s)
Could you email through the gtzip file? I've tested it with the same parameters but am not seeing the same issue.
ask
#97 Posted : Monday, January 14, 2019 12:23:15 PM(UTC)
ask
Sent through.. Now if I enter a larger duration, then set another field, then save it seems to work. You can see the duration written if you open the gzip file in notepad. So it seems to only save the first number if you haven't shifted the focus out of the field.
Also, if you input a large amount of text into the title in Text Editor, it seems to only display about the first 8-12 lines (depending of ext size). Remaining text is not shown. This works fine in Legacy TD. Changing the size of the text box in GT helps....but still not enough so see all input text.
wtmuradiotv
#98 Posted : Tuesday, January 15, 2019 9:58:07 AM(UTC)
wtmuradiotv
So far so good !!! and as far as the cg works great !!!
#99 Posted : Wednesday, January 16, 2019 12:08:23 PM(UTC)
vMix Beta 22.0.0.42 has been uploaded
http://cdn.vmix.com/download/vmix22preview.exe
* Added Activators support for Stream Deck
* Fixed connection issues with Stream Deck
* Added support for resizable VST3 plugins
* Fixed audio issue with vMix AVI in Magix Vegas
* Fixed configuration issue with NDI sources in Replay
* Support for Kona 5 added
* Improved reliability of Sony VISCA over IP provider
* Number of GT fixes including zoom scrolling for 4K templates, image update, duration dropdown and data change animation issues.
* Latest NDI 3.8 fixes included
thanks 11 users thanked admin for this useful post.
SHMD on 1/16/2019(UTC), Video Dave on 1/16/2019(UTC), ask on 1/16/2019(UTC), monamiga on 1/16/2019(UTC), rowby on 1/16/2019(UTC), sinc747 on 1/17/2019(UTC), mjgraves on 1/17/2019(UTC), seb666 on 1/17/2019(UTC), corporatejames on 1/17/2019(UTC), stevespaw on 1/18/2019(UTC), QuiapoChurch on 1/21/2019(UTC)
SHMD
#100 Posted : Wednesday, January 16, 2019 12:21:45 PM(UTC)
SHMD
Canada
Awesome!
8 Pages«<34567>»
