Copy Title Mapping from data source into other project
Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Sorry for my english, translated with google translate.
Is it possible to copy the Data Mapping of a title into other titles within the usual project (by changing "Data Source" files if i need) or even in other projects?
thanks a lot
yes
when you save all as a preset and then open the preset and append that title only from this preset you will get a duplicate with the same settings , then edit/change it to the wanted title. Guess you might need to have the textfields have the same name though (have not tested that )
Joined: 10/25/2021(UTC) Posts: 1  Location: Fort Lauderdale
would this allow someone to access 'pre-made' titles across differnt projects? I would really like to be able 'import' or 'open' titles that i create in one project another project ... ty!
