shai
#1 Posted : Thursday, January 3, 2019 5:50:23 AM(UTC)
shai
Israel
I’m looking for an application that can control PTZ camera presets over IP.
The 4 cameras I have today are PTZOptics Gen2.
Today I control the presets via vMix.
What I miss, is the option to create one button, that control 4 presets in one click.
For example: I would like to create for each camera a preset to the right side of the hall. Then, I would like to have a button that holds all 4 presets of the right side, and once I click on it, it will activate all 4 presets together.
I hope I’m clear here 😊
Any ideas are welcome
Thanks,
Shai
seb666
#2 Posted : Thursday, January 3, 2019 7:51:55 AM(UTC)
seb666
Thanks,
Shai
You should be able to realize this via vMix. Make presets for every camera, put the four presets shots you want to use in one blank shot via Multiview. Then you can get this Multiview shot in Preview and all cameras should adjust as you need it.
If you are looking for some great IP based controllers for PTZ cameras and vMix have look at Skaarhoj's control panels:
https://www.skaarhoj.com/
They have different controllers and I like the PTZ Pro very much.
thanks 1 user thanked seb666 for this useful post.
shai on 1/3/2019(UTC)
