*Solved* I'm noticing a fair amount of ghosting from my cameras (ptz-optics, both over hdmi and over network) that wasn't there in 21.
Intel i7 7700 Gtx 1060 6gb 1080p@30 windows 10
Reverting back to 21 for now unless there is a fix for this. Thanks!
Edit: It's persisting now that I'm back on 21, either something changed or I'm going crazy. Final Edit: The noise reduction on my cameras got pumped up to max for some reason which was causing the ghosting, not vmix!
Huuuge thanks for v22 and all the wonderful new features! Quote:Create Snapshot added to input cog icon menu to create a high resolution snapshot of any input Snapshot not available if the Input has PTZ connected. Quote:Live Pause. Camera, NDI and Desktop Capture inputs can be paused by clicking the pause icon under the input I'm probably blind, but I cannot find the pause icon Quote:New GPU memory % indicator in status bar Personally I would prefer to have this left of the Render time (as to not confuse with the other % meters) Quote:text fields in GT are now called Name.Text instead of just Name We are looking into how SmartTitler can be adopted to work with GT, and I guess developers of other apps that interact with the XAML Title inputs face similar considerations. It would be useful to know more about how the .Text (and similar extensions) affect API calls when SelectedName is used. That is, should the extension be included or not in the Value? (Ideally not, in order to make app adoption smoother). Lastly, (this will be a) HAPPY NEW YEAR!
 1 user thanked richardgatarski for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Quote: Quote: Live Pause. Camera, NDI and Desktop Capture inputs can be paused by clicking the pause icon under the input
doggy, why oh why embarass me publically? You could have discretely sent me a pm... LOL!
thx :)
Originally Posted by: richardgatarski  doggy, why oh why embarass me publically? You could have discretely sent me a pm... LOL!
thx :) LOL Be aware that it changes into a play button when pressed so you will then not see it anymore ;-)
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4790 time(s) in 1644 post(s)
22.0.0.37 beta has been released* Added ability to copy Input Settings from another input. Click the Copy From button at the bottom left hand side and select from Triggers, MultiView and Colour Correction to copy over. * Added Clock dropdown in the built-in Title Editor with presets for common clock formats * Added customisable zoom options for Virtual PTZ, from 2x to 10x. * Fixed images not saving correctly in gtzip titles * Fixed continuous animations not starting for image sequences * Fixed create snapshot menu not appearing when connected to PTZ * Fixed performance issues using reflection with image sequences * Fixed some potential memory leaks in titles * vMix Social updated with fix for Facebook Post photos http://cdn.vmix.com/download/vmix22preview.exe
 4 users thanked admin for this useful post.
These 2 bugs still remain in .37
- problem with Title Editor window staying on top of everything when giving focus to another software's window. I guess it should go in the background (like vMix UI) not to occult the other app.
- When using GT titles, right-clicking the title input thumbnail no longer displays the different text values (entered and stored manually or by CSV in Title Editor) that are available for this title...
Thanks Guillaume
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: richardgatarski  Quote:Live Pause. Camera, NDI and Desktop Capture inputs can be paused by clicking the pause icon under the input I'm probably blind, but I cannot find the pause icon You are not the only one: Sorry Tom :)
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
Hi everybody
I found a kind of "bug" in v22. When using a joystick in Germany pressure sensitive PTZ Joystick support doesn't work properly. I think this is caused by our decimal separator. Here we use a comma to separate the decimals (0,6 instead of 0.6). vMix uses the windows-built-in region settings for this decimal separator, so I have to go to my windows control panel and change it there in a quite hidden menu for my entire computer and all other applications. After a restart the PTZ feature works. Can you change this please, that also European users can use joysticks and keep their normal regional settings?
Best regards Yannick
 1 user thanked krassesPferd for this useful post.
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Thanks Guillaume *************************************** Same report from me I tested emidiately those two bugs and it remains Old titel works, but GT Titels doesn´t work Gunnar Göransson Sweden
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everybody,
Testing latest update 22.0.0.37 beta
* Added ability to copy Input Settings from another input. REALLY NICE. I am certain this will be popular * Added customisable zoom options for Virtual PTZ, from 2x to 10x. Great to see this. Especially since it was just recently requested on the Forum. However Virtual PTZ zoom is still not working with my X-Keys joystick. I sent X-Keys a support ticket about my issue. Kinda ironic because I assume the Virtual PtZ Feature was added to 22 because of my feature request 😀.
Rowby
Originally Posted by: Ronald555  Originally Posted by: richardgatarski  Quote:Live Pause. Camera, NDI and Desktop Capture inputs can be paused by clicking the pause icon under the input I'm probably blind, but I cannot find the pause icon You are not the only one: Sorry Tom :) Finally found it! It was camouflaged as a Pause Button like on a Video or Audio Input. - Tom
As shown 11 reply's above ;-) Originally Posted by: sinc747  Originally Posted by: Ronald555  Originally Posted by: richardgatarski  Quote:Live Pause. Camera, NDI and Desktop Capture inputs can be paused by clicking the pause icon under the input I'm probably blind, but I cannot find the pause icon You are not the only one: Sorry Tom :) Finally found it! It was camouflaged as a Pause Button like on a Video or Audio Input. - Tom
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Rowby Rowby I remember giving up on the the twist zoom of the xkeys a while back when I was testing it and went with an xbox controller. If I remember correctly xkeys joystick uses a Z-rotation instead of Z-axis for zoom control. Maybe this is the issue you are having? -s
Hi. SHMD
Thanks for that info. That probably explains the mystery.
I will forward your comments to X-Keys support and see what they have to say about that —and I may have to return their joystick.
Or maybe they will offer a workaround.
For those considering the XKeys joystick. x-Keys support responded to my support ticket....
Unfortunately there is no workaround the for that zoom on our joystick, we are working on an updated design that will but that unit will not be available for some time yet. If you’d like to return the unit and you purchased it directly from us send me your invoice and I’ll get that return started for you (we have a 30 day return period and the clock was paused on the date of your first email to us). If you did not purchase it directly form us please return it to whomever you bought it from.
Joined: 4/1/2017(UTC) Posts: 14   Location: Leuven-Belgium Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
*UPDATE: the GT Social input/overlay not showing up seams to be fixed in .37.
I had an issue wit GT social (Kimono) yesterday. It worked fine with Twitter but as soon as I send one Facebook post it stops updating. After that nothing I would send would update he data or trigger the overlay (that is set to disappear after a few seconds).
Only solution was to remove the input and recreate a new GT Social input (and don't send any Facebook posts).
Think I'm still using a older beta (the main downoad button in the begin of this thread), I'll try this again tonight with v 22.0.0.37.
One small thing I thought to report, but is already present in v21 When you have an overlay that disapaers after, let's say 10 seconds, the timeout does not reset when sending a new social post. Let me explain in steps :-) 1. You have a social input on a overlay that has a timeout of 10 seconds. The input is not visible 2. You send a social post that triggers the overlay and input showing the social post on screen. 3. After 9 seconds you send a second social post, the content of the data on the input changes live. 4. After 1 more second the 10 second time out triggers and hides the overlay/input from screen. So the second post has only showed for 1 second. It would be good if the overlay timer get's reset when you send a new social post to that overlay so the second social post get's his own 10 seconds.
Joined: 12/3/2013(UTC) Posts: 17  Location: Netherlands Was thanked: 2 time(s) in 2 post(s)
Love the ability to copy input settings from another input! Would it be possible to also add the position settings?
Brian
vMix Beta 22.0.0.38 Releasedhttp://cdn.vmix.com/download/vmix22preview.exe* Added cog buttons on Preview and Output to open up Input Settings * Added ability to solo Bus A or Bus B through the Headphones output. Click the [S] in the Bus mixer to toggle on/off. * Fixed vMix Video Codec blank frame issue in latest Magix Vegas and Adobe Premiere * Fixed right click presets menu not working for GT titles * Fixed Title Editor and Audio Settings windows appearing on top of other applications * Fixed Joystick pressure problem in regions with "," decimals. * Fixed issue where hiding a mask didn't update objects using the mask correctly. * MultiView Layout settings now support selecting inputs 1-300. This release should fix all outstanding bugs we are aware of. If we have missed your report please do let us know again in this thread.
 12 users thanked admin for this useful post.
DWAM on 1/4/2019(UTC), NHT on 1/4/2019(UTC), Joeboe on 1/4/2019(UTC), seb666 on 1/4/2019(UTC), SHMD on 1/4/2019(UTC), sinc747 on 1/5/2019(UTC), MycroBeat99 on 1/5/2019(UTC), vijay6672 on 1/5/2019(UTC), rowby on 1/6/2019(UTC), corporatejames on 1/6/2019(UTC), monamiga on 1/7/2019(UTC), Teye on 1/8/2019(UTC)
Joined: 6/16/2013(UTC) Posts: 15   Location: Netherlands,Lelystad Thanks: 27 times Was thanked: 1 time(s) in 1 post(s)
GT Title editor doesn't remember speed of the cube rotation when choose continous effect
