funky_f
#1 Posted : Friday, December 28, 2018 10:15:33 PM(UTC)
funky_f
1. It would be wonderfull, if vMix had more audio buses for audio routing.
2. For some reason rtmp stream input does not have an advanced audio setting cog button, but it's realy needed.
3. It's very inconvinient that master bus and headphones bus are together on M button on input in audio mixer. Please, make separate H button for headphones bus, so it could be used as intended, as PFL.
And thank you for your amazing product! I only wish it would get better and better.
Barney Box Lane
#2 Posted : Monday, December 31, 2018 10:25:38 PM(UTC)
Barney Box Lane
for extra buses we use multiviews to create extra ones.
say you want to have a mini studio at the back of sight with three cameras and you've already got 2 main busses going on and you might want to cut from either of those areas to the new mini studio.
pick a main camera for your audio/Mic to plug into. Then overlay that camera on the other two cameras using multiview. Then move that overlay off screen on both of the other cameras.
on the main camera have have automatically mix audio ticked. On the other two have it unticked and switched off/turned down so there's no clashes.
this way you can create lots of buses and areas for the live output
geofhill
#3 Posted : Monday, January 7, 2019 9:03:32 AM(UTC)
geofhill
YES...need way more audio buses.. 40 would be great...then I can match my x32 system properly
