Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Hello everyone. You've been the best of all for me long enough to know what version. I know we all want to read Version 22, but maybe it's okay to fix a small bug in the 21st. First bug: So ticker when SAVE present and again OPEN present ticker again in the default format. Specifically, the letter size returns to 45. Although we set it up for example 20, it automatically returns to 45.
Another bug: I am from Croatia, so you have not noticed that fashion. So, when uploading to a List Editor, an image or other file must be written only without Latin characters. Therefore, Českýchží does not support and there is an error. The same is the name of the directory. If Vmix can not read it with that letter.
There's so much. They are not big problems but if they can be corrected it would be great. LP and we hear. All the best in 2019.
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Due to a limitation in how the tickers work in 21, it is not possible to save all the information in them while playing. Please pause the ticker before saving the preset.
As for the List, I have just tested with a video called Českýchží.mov and it added correctly. If you are referring to importing .m3u make sure the file is saved in UTF8 format.
Martin vMix
The List input is designed for videos only. Use the photos input instead for images.
Martin vMix
Hehe when I use video and photo because then I'm all in one. She also shows beautiful pictures and videos, just what I have to write without a spell šđščžć. It's not a problem, just think it's a problem. It would be good if they had united for everything and for video and photo and other files because this is something that can be used for everything.
