Limit on audio inputs for external devices?
G'day.
Wondering if anyone has experience with external audio devices - we'd like to run 8 audio channels into vMix using a single audio capture device. Has anyone done this and can recommend a unit?
Cheers, Josh
No problem with my MOTU UltraLite AVB. But any interface with ASIO drivers should work fine. Cheapest option is a Behringer UMC1820.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
Agree with Ovinas. I've used a Behringer Audio Interface (UMC404HD - 4 input) for years and it works very well. Martin & Tim use the same one for the monthly vMix Fun Time Live Show, too.
- Tom
I own a Tascam US-16x08 - 8x mic inputs, 8x line inputs, 8x outputs, and it works fine with vMix using the ASIO drivers to get access to all the inputs. Plus it has an internal DSP-based monitor mixer which can be useful too.
Thanks: 2 times Was thanked: 7 time(s) in 5 post(s)
I have used a ZOOM R16 for a couple of years now. 8 XLR inputs (only Phantom power on 2) and it also works as midi faders with vMix. Powered through USB.
