NDI
The NDI problem with the second PC
Thanks: 74 times Was thanked: 7 time(s) in 7 post(s)
hello to all the forum colleagues I own a Vmix Pro license, and I recently installed the license on a second device (laptop), the first being on a pc. After installing vmix on my laptop, NDI does not work on my first PC, it only works on my laptop. Hoping to give me some advice on this issue, thank you in advance. A wonderful day for everyone!
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
Yes, before it worked perfectly. It all happened after installing the second PC (laptop). Both were connected to the same network. I'm interested in how to make the first pc work properly. I will try the solution proposed by you. Thanks a lot for your help
Originally Posted by: Chircanu  hello to all the forum colleagues I own a Vmix Pro license, and I recently installed the license on a second device (laptop), the first being on a pc. After installing vmix on my laptop, NDI does not work on my first PC, it only works on my laptop. Perhaps this is the reason Quote:Each license can be installed on up to two PCs or Laptops in total as long as vMix is not being used on both at the same time. https://www.vmix.com/knowledgeba...lled-on-more-than-one-pc
 1 user thanked SportsNetUSA.net for this useful post.
Originally Posted by: Chircanu  Yes, before it worked perfectly. It all happened after installing the second PC (laptop). Both were connected to the same network. I'm interested in how to make the first pc work properly. I will try the solution proposed by you. Thanks a lot for your help Just to eliminate vMix and concentrate on the NDI aspect, have you also included running copies of NewTek's NDI Tools (Test Patterns and Studio Monitor) on both PCs, to see if they can interconnect from one PC to the other, as well as locally on their respective host PCs?
Hello everyone, with your help, I understand what is the cause of the problem I have reported. When I installed vmix on the second pc (laptop), it took over the main pc function and the secondary pc. Q: how can I solve the pc's main problem, and the secondary laptop? I insist on this issue because the laptop is using it to insert the graphics. thank you for all your support!
Originally Posted by: Chircanu  Hello everyone, with your help, I understand what is the cause of the problem I have reported. When I installed vmix on the second pc (laptop), it took over the main pc function and the secondary pc. Q: how can I solve the pc's main problem, and the secondary laptop? I insist on this issue because the laptop is using it to insert the graphics. thank you for all your support! You have to purchase a second licence to do this. VMix can not run on two PC's at the same time.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
I think it's because your pulling the same ndi source to two computers, that will do it if you're not set up right. Shut down the one that's working while you work on the other
Quote:I think it's because your pulling the same ndi source to two computers Definitely not! That's the main benefit of NDI and that's the beauty of it: there are no such limitations
NDI
