8 Pages<1234>»
#21 Posted : Thursday, December 20, 2018 12:31:47 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
Originally Posted by: NHT Go to Quoted Post
It's now also stopped my BASIC HD from working because it keeps trying to load the Beta.
Please refer to the large "Update" note in the original post. You will need to purchase an update most likely
or go back to vMix 21 again by installing over the top and reactivating your key at https://account.vmix.com/
ask
#22 Posted : Thursday, December 20, 2018 12:45:16 PM(UTC)
ask
Love that newly designed titles appear in the Recent tab of the title selection window! Great hidden feature!!!! Well done Martin....and Tim.:-)
thanks 2 users thanked ask for this useful post.
rowby on 12/21/2018(UTC), sinc747 on 12/21/2018(UTC)
bgbenni
#23 Posted : Thursday, December 20, 2018 6:54:02 PM(UTC)
bgbenni
Germany
Thank you for the new Version the PTZ zoome is what i Need since a Longe time!
I have a question with the ptz shurtcuts, i will use the zoome in out and move left right funktion with the numpad the problem is if i set zoom in on + its zoom in to 100%.
is it posible to set the movment and zoom by klick
for each klick on + its zoome in a litle bit more.
The same for the other funktion move left right up and down.
THX
#24 Posted : Thursday, December 20, 2018 7:06:24 PM(UTC)
Though it's possible it's obviously not ideal or recommended.
If you want to do so, you need to use the PTZZoomStop and PTZMoveStop commands in order to control manually the zoom and move range
Guillaume
gefiltafish
#25 Posted : Thursday, December 20, 2018 7:50:47 PM(UTC)
gefiltafish
Hi guys, I have a question.
How are x and y coordinates going to be calculated in GT?
I'm asking because Title Designer calculates them differently than Photoshop or Illustrator, regardless of the anchor point. (or perhaps I'm missing something)
bgbenni
#26 Posted : Thursday, December 20, 2018 7:51:38 PM(UTC)
bgbenni
Germany
I have test it with the ptzzoomstop direkt afther the Zoom but it’s not working becous i don’t can give a delay. I think I must build I own keyboard macro :(
#27 Posted: : Thursday, December 20, 2018 8:50:46 PM(UTC)
Again PTZ are NOT supposed to be managed with a keyboard, but a joystick
#28 Posted : Friday, December 21, 2018 2:37:56 AM(UTC)
vMix Preview 22.0.0.35 released
http://cdn.vmix.com/download/vmix22preview.exe
* Fixed Auto column mapping issue in Data Sources with GT files.
* Fixed GT Layer numbering when creating Group Layer.
* Fixed GT saving issue in regions with "," decimal point.
* Fixed GT TransitionOut stuck issue in some cases on 59.94p/60p productions.
* Added Logitech Rally PTZ support for 4K via MF capture.
thanks 12 users thanked admin for this useful post.
DWAM on 12/21/2018(UTC), Quinton on 12/21/2018(UTC), rowby on 12/21/2018(UTC), vijay6672 on 12/21/2018(UTC), SHMD on 12/21/2018(UTC), monamiga on 12/21/2018(UTC), MycroBeat99 on 12/21/2018(UTC), sinc747 on 12/21/2018(UTC), madness on 12/21/2018(UTC), mjgraves on 12/22/2018(UTC), LesterF on 12/23/2018(UTC), corporatejames on 12/23/2018(UTC)
mjgraves
#29 Posted : Friday, December 21, 2018 7:15:04 AM(UTC)
mjgraves
There's still something amiss with accessing the Rally camera.
Selecting:
Camera: Logitech Rally Camera MF
Resolution: 3840x2160 (or 4096x2160)
Frame Rate: NTSC 30p
Video Format: Default
Audio: Disabled
Results in:
"AddNewInput
Video format not supported by device"
Selecting:
Resolution: 1920x1080 (or less)
Audio: Disabled
Results in: Success!
Selecting:
Video Format: NV12
Audio: Disabled
Selecting:
Video Format: NV12
Audio: Disabled
Results in:
AddNewInput
It would seem that there is some difference between Brio and Rally. Brio works with NV12 at all resolutions, including 4k. Rally seems to require MJPEG to reach 4K.
sinc747
#30 Posted : Friday, December 21, 2018 3:46:09 PM(UTC)
sinc747
Possible bug with a new GT title...
See the video here:
?t=577
When I attempted to re-position the title using the Pan Y control (from the Position tab in the title Input), the title became crushed. When I re-positioned the title by drag-and-drop, it moved okay.
It was probably just me.
- Tom
Vuurmannetje
#31 Posted : Friday, December 21, 2018 5:21:56 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Some things Ive noticed, GT designer side
- As soon as Ive got multiple items placed in a vertical plane (leaderboards) I have trouble aligning them with Snap Align on. When dragging any item it will constantly snap to different places and make it impossible to move.
- When manually editing Animation time/duration times, sometimes the number will reset to default if I put in a round number. No issues with any decimals
- When editing multiple item animations, as soon as you change any of the timings or animation smoothness, it will overwrite individual timings of all those parameters to all selected items, rather than just the edited one. For example, I have a bunch of bars above each other with staggered animation starts. When I edit the duration, it will set the delay and smoothening to the displayed items parameters to all selected bars. This does not happen if I change the animation type tho.
- When selecting font, I can not mouse scroll wheel through the list after opening the dropdown (think its the same for the other dropdowns. Scrolling does work with a closed list selected.
floz23
#32 Posted : Saturday, December 22, 2018 2:47:40 AM(UTC)
floz23
Was thanked: 7 time(s) in 5 post(s)
Is this beta safe to install alongside vmix 21? I'd like to test it, but I don't want to lose vmix21 functionality for actual production.
thank you,
-Adam
#33 Posted : Saturday, December 22, 2018 5:14:23 AM(UTC)
I think there is a problem with Title Editor window staying on top of everything when giving focus to another software's window. I guess it should go in the background (like vMix UI) not to occult the other app.
#34 Posted : Saturday, December 22, 2018 5:39:31 AM(UTC)
Another problem?
When using GT titles, right-clicking the title input thumbnail no longer displays the different text values (entered and stored manually in Title Editor) that are available for this title...
Is this by design or a bug?
I hope it's not by design 'cos it would force us to create shortcuts to select values in basic titles
Guillaume
thanks 2 users thanked DWAM for this useful post.
rowby on 12/22/2018(UTC), daniel514 on 12/23/2018(UTC)
#35 Posted : Saturday, December 22, 2018 12:33:06 PM(UTC)
This appears to be a bug, the presets should be showing in the right click menu.
NHT
#36 Posted : Sunday, December 23, 2018 12:31:11 AM(UTC)
NHT
Trying to run the GT on my laptop but getting this error message.
Machine is:-
Dell Latitude
i5
Intel HD GFX
Win 7 64
#37 Posted : Sunday, December 23, 2018 12:41:09 AM(UTC)
Posted yesterday !
https://forums.vmix.com/...nsupported----2005270524
NHT
#38 Posted : Sunday, December 23, 2018 1:14:28 AM(UTC)
NHT
Posted yesterday !
Thanks Guill :)
Joeboe
#39 Posted : Sunday, December 23, 2018 1:33:23 AM(UTC)
Joeboe
I have a question...will the QT titles work in any of the older versions of vMix.....
stigaard
#40 Posted : Sunday, December 23, 2018 5:52:04 AM(UTC)
stigaard
Denmark
No, they are not backwards compatible. It is only for vMix 22 and onwards.
thanks 1 user thanked stigaard for this useful post.
Joeboe on 12/23/2018(UTC)
Guest (15)
8 Pages<1234>»
