Joined: 11/27/2017(UTC) Posts: 17   Location: Louisville, Kentucky Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
When I create the score widget it only shows +1 to the right as a way to change the score. It displays properly with older versions of UTC controller (showing +1, +2,+3 in the lower right hand corner, but not with the latest release. Any ideas?
Thanks: 73 times Was thanked: 7 time(s) in 7 post(s)
Originally Posted by: timbrian  When I create the score widget it only shows +1 to the right as a way to change the score. It displays properly with older versions of UTC controller (showing +1, +2,+3 in the lower right hand corner, but not with the latest release. Any ideas? Hello, in my opinion, the problem you have can be resolved as follows: enter the score widget, and in the "style" section you have more options to display the score. Basic, Basketball, Rugby and American Football. Depending on the option chosen, the score units will be changed. I hope I have understood and it is helpful
 1 user thanked Chircanu for this useful post.
Originally Posted by: Chircanu  Originally Posted by: timbrian  When I create the score widget it only shows +1 to the right as a way to change the score. It displays properly with older versions of UTC controller (showing +1, +2,+3 in the lower right hand corner, but not with the latest release. Any ideas? Hello, in my opinion, the problem you have can be resolved as follows: enter the score widget, and in the "style" section you have more options to display the score. Basic, Basketball, Rugby and American Football. Depending on the option chosen, the score units will be changed. I hope I have understood and it is helpful Thanks Chircanu I appreciate that. That did the trick!
