mgrayeb
#1 Posted : Thursday, December 20, 2018 1:47:45 PM(UTC)
mgrayeb
Can anyone advise on how I can edit one of the GT animated lower third templates in the GT Designer? For example, how do I find where those templates are located (file folder) and then how do I open those in the GT Title designer so I can change the colors of the elements and/or modify the template shapes, sizes, etc.
Thanks.
#2 Posted : Thursday, December 20, 2018 2:26:42 PM(UTC)
If you open the template in vMix, it will then appear in the recent list in the GT Designer File menu.
Note that you should save it to a separate location once the changes have been made and that any animations
in the modified template will not play into editions lower than vMix 4K.
mgrayeb on 12/20/2018(UTC), ThomasK on 4/7/2019(UTC)
mgrayeb
#3 Posted : Thursday, December 20, 2018 2:34:55 PM(UTC)
mgrayeb
Great; thank you!
