guztavo
#1 Posted : Monday, December 17, 2018 1:59:06 AM(UTC)
guztavo
Hi!
I want to share this idea, so you can tell me if will work, or what do you think..
I will stream sports, with two cams. The idea is to get two mics over the Sony NX5 cam. Then CAM 1 & CAM 2 connected to a small PC with medialooks NDI transport.
In the otherside, the control room recieve this two signals, mix them, put overlays, replay and all extra things. So no video production on the game field.
Output to TV station and back to stadium over medialooks NDI transport.
This small setup avoid to move equipment to the stadium.
Camera operator comunication over cellphone
What do you think? Are you using something like this?
Regards!
Siroki
#2 Posted : Monday, December 17, 2018 5:50:34 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: guztavo Go to Quoted Post
Hi!
Regards!
I saw similar idea in Slovakia where some company hold rights for all sports and make all games live on this way you say. They send video signals to center where everything else is added
edit:
found it
Live video streams from JVC cameras at the stadiums, are received at the production center in Bratislava, where all production takes place. Highlights and replay packages are produced in real time, and at the same time, audio commentary, and graphics are added.
https://huste.joj.sk/
Best regards
JimJacobs
#3 Posted : Monday, December 17, 2018 7:49:41 AM(UTC)
JimJacobs
No substitute for being there, plus the obvious delays introduced with the NDI feeds over net. You scheme will technically work, but I find it hard to imagine the finished product equaling one created at the stadium.
guztavo
#4 Posted : Wednesday, December 19, 2018 7:30:49 AM(UTC)
guztavo
Thanks for answering.
I see that internet speed don't allow this setup works, so i will keep in mind for 2020.
If i use a van, the control room isn't in contact with the field. I don't see any difference... But i will try with any event and give you feedback.
Thanks!!
imintmedia
#5 Posted : Wednesday, December 19, 2018 12:19:21 PM(UTC)
imintmedia
I have done work with these guys. Everything is Newtek and the coms are IP based but a pretty cool setup.
https://www.newtek.com/b...ough-the-cloud-with-ndi/
