#1 Posted : Wednesday, December 19, 2018 8:31:33 AM(UTC)
Was thanked: 795 time(s) in 589 post(s)
And available for download here:
https://www.newtek.com/ndi/
New NDI Tools features include: Scan Converter now supports high frame-rate screen capture for game capture; likewise Studio Monitor has been updated to support high frame-rate playback; Virtual Input has separate signed drivers for Windows 10 and previous versions, allowing it to correctly run on all Windows versions.
Guillaume
Integrion
#2 Posted : Monday, February 4, 2019 10:51:52 PM(UTC)
Integrion
It appears that this link is broken, and the Newtek website appears to have a download link problem, as none of the links on the Newtek website appear to work. Does anyone know where else we can get the latest version of the NDI Tools?
Thanks!
spino
#3 Posted : Monday, February 4, 2019 10:54:11 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
Thanks!
It works for me.
Integrion
#4 Posted : Tuesday, February 5, 2019 12:19:33 AM(UTC)
Integrion
Ok, problem solved...
It appears the download links on the Newtek site don't work if one is using an ad-blocker extension in their browser. Disabled the ad-blocker, refreshed the page... and voila, the download links indeed work. Ad-blocker extensions apparently block the required Javascript from running on the page, which then prevents the download buttons from working correctly.
Thanks!
