Playing a Vmix to another pc
Hello How are forum members? My question is this .. I want to know if it is possible to stream a Vmix to another .. and if possible as I can achieve this?
Joined: 6/29/2011(UTC) Posts: 313   Location: Florida Thanks: 6 times Was thanked: 33 time(s) in 32 post(s)
Bertin Do you know how to setup Microsoft Expression Encoder 4? This would be one way. Just by setting the stream to local then point player PC's to streaming IP address The same thing can be done with VLC and setting it to stream local then on player PC use VLC to grab stream. There will be delay introduced but if player and streamer are not in local area it won't matter. hope this helps
Egriswold wrote:Bertin Do you know how to setup Microsoft Expression Encoder 4? This would be one way. Just by setting the stream to local then point player PC's to streaming IP address The same thing can be done with VLC and setting it to stream local then on player PC use VLC to grab stream. There will be delay introduced but if player and streamer are not in local area it won't matter. hope this helps But there is a way to open what is in another Vmix Vmix a different pc?
My first thought is to use desktop capture utility, have vMix #1connected to two monitors with fullscreen active on monitor two and screencapture utility active. Then vMix #2 add desktop capture and point to screen two over the network. hope this is understandable.
