slxxi
#1 Posted : Thursday, December 13, 2018 1:58:58 AM(UTC)
slxxi
To simplify the Setting:
I would like to have 4 Playlists, each containing 10 different 10second long Videofiles.
The 4 Playlists are positioned via Multiview-Layers of a Blank Input.
So far, so good. I can start each Playlist by Hand, but naturally they are out of Sync.
Is there a way to start all of the Playlists at the same time, so all 4 Playlists are in Sync?
Thanks in advance
Vuurmannetje
#2 Posted : Thursday, December 13, 2018 2:40:01 AM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
No easy way to keep them in sync, but to start them all at the same time theres 2 easy ways:
- Create 4 shortcuts with the same hotkey to start the lists
- Create 4 triggers in a transparent input to trigger onOverlay in. then just put that on any overlay to trigger playback. Alternatively put the triggers on whatever you put live when you want them to start and change it to TransitionIn
slxxi
#3 Posted : Friday, December 14, 2018 8:07:10 PM(UTC)
slxxi
Thanks for this trick, I'll give it a try
