mixsystem
#1 Posted : Friday, November 30, 2018 9:52:52 AM(UTC)
mixsystem
Good evening, I should record the video from the vmix program and the audio from an external source other than the vmix master.
on the streaming and external I have to send the master.
adding an input sound card and selecting the output of the latter to the busB and the recorder imposed busB as an audio source, this remains silent, does it happen to you too? or is it a bug?
thank you
Ettore
richardgatarski
#2 Posted : Friday, November 30, 2018 7:26:47 PM(UTC)
richardgatarski
I just tried with 21.0.0.55 and it works just fine.
You need to have an Audio output device selected for Bus B, and then as you say assign your input to that Bus B. And of course set Bus B as audio source in the Recorder.
If these remarks does not help, please explain your Audio setup in more detail.
mixsystem
#3 Posted : Sunday, December 2, 2018 10:25:47 PM(UTC)
mixsystem
it's perfect, you need to configure an output perfusion, otherwise you can not direct the audio to the bus
thank you
