I have the 4k versions and get one camera instant replay. I can't use instant replay and multi corder at the same time. My question is can you set the instant replay to to record to just one file instead of making a new file every 20 mins?
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ WWLivestream
The short answer is YES.
Joined: 8/5/2015(UTC) Posts: 51  Location: Germany Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
@IceStream
Would you mind sharing where you've found this option? I see an option for "New File Every ..." in the "Record" and "Multicorder" options, but not in the IR settings/options?
Knut
Ice Any info would be great.
"My question is can you set the instant replay to to record to just one file instead of making a new file every 20 mins?"
The Instant Replay session is just one file, you can extract and export whatever "clips" you want from it. Perhaps you ment to ask something else...
Quote: The Instant Replay session is just one file, you can extract and export whatever "clips" you want from it. Perhaps you ment to ask something else...
I think he actually means the videofile being written, not the session file. The videofile is always split at around 20 minutes which relates to about 15GB when recorded at 100mbit/s, unless I'm mistaken. Knut
Originally Posted by: dasmedienatelier  Quote: The Instant Replay session is just one file, you can extract and export whatever "clips" you want from it. Perhaps you ment to ask something else...
I think he actually means the videofile being written, not the session file. The videofile is always split at around 20 minutes which relates to about 15GB when recorded at 100mbit/s, unless I'm mistaken. Knut That is exactly what I am talking about. You can't use the multicorder and ir at the same time. I need one file of only one input.
