Joined: 11/26/2018(UTC) Posts: 29  Location: Rome Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hello everybody. I don't undestand: in some PC I can use Vmix Browser and open Flash pages (eg: Youtube streams), in other PC it's all damn slow and doesn't works fine. Why? What I can update? If I go on www.whatismybrowser.com with Vmix browser I see this: https://i.postimg.cc/b8R6DrbS/Image1.jpgWell... what's the problem? I must do something in "C:\Program Files (x86)\vMix\browser"? Thanks again.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
vMix created their own browser instance which is used in vMix. It is based on chrome v62 and you cannot update the browser like you do with chrome. Perhaps vMix 22 will have an updated browser.. Originally Posted by: carsco  Hello everybody. I don't undestand: in some PC I can use Vmix Browser and open Flash pages (eg: Youtube streams), in other PC it's all damn slow and doesn't works fine. Why? What I can update? If I go on www.whatismybrowser.com with Vmix browser I see this: https://i.postimg.cc/b8R6DrbS/Image1.jpgWell... what's the problem? I must do something in "C:\Program Files (x86)\vMix\browser"? Thanks again.
Check your Internet Options in the control panel under Security -> Security Level -> Custom Level on both PC, the one that works and the one that doesn't and set options the same. Originally Posted by: carsco
Just tried: these settings only affect Explorer, not Vmix Browser (or any other browser). There is no way to modify cookie setting, I think.
