Hardware Compatibility
Hardware encoding without NVIDIA
Joined: 11/26/2018(UTC) Posts: 29  Location: Rome Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hello. There is a way to obtain availability of "hardware encoding" with 8th gen Intel CPU?
I'll better explain.
I've a Nvidia GT1030 (without NVENC) on a Z370 with 8th gen Intel i5 8400 (that has UHD630 QuickSync GPU).
GT1030 doesn't have any HW encoder. UHD630 (the GPU within the i5) has QuickSync, that I use with Handbrake, for instance.
QuickSync is a VERY fast way to encode in Handbrake, compared to the CPU.
Why, when I choice "GT1030" in "performance", I've the checkbox "Use hardware encoder" availability even if GPU doesn't have NVENC? Obviously, if I try to encode, it doesn't works.
And why, when I choice "UHD630" in "performance", I've not same checkbox availability? UHD630 doesn't suitable for this?
I'm confused about this. Does Vmix use ONLY NVENC or other engines, like QuickSync.
An AMD RX GPU will works? And what about a Ryzen 2400G (with Vega GPU)?
Thanks for attention.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Not sure about the QuickSync encoder in the CPU. Will be interesting to see how admin replied.
The encoder in the AMD GPU is definitely not supported.
If QuickSync is not supported, I would suggest replacing the GPU with one that offers NVENC.
Originally Posted by: mjgraves  If QuickSync is not supported, I would suggest replacing the GPU with one that offers NVENC. It's my last chance, but QuickSync it's a VERY GOOD and cheapest encoder. When VMIX will supports FFMPEG3-4 maybe it works.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
You can use QSV externally of vMix. I agree it's fast and very low on resources.
Just use EXTERNAL out to feed your own encoder with QSV support (for example FFMPEG or OBS)
Guillaume
Originally Posted by: DWAM  Just use EXTERNAL out to feed your own encoder with QSV support (for example FFMPEG or OBS) I've a little fps loss when I import 60fps Vmix video to OBS. Better adopt FFMPEG3 (we are on FFMPEG4).
