 Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
                Hi Whilst it is possible to select the Category in the API using  SelectCategory there seems no provision in the AP XML that is returned to ready which Category is currently displayed, or more importantly which category any given inputs is assigned to. Would it be possible for the APIto return  Category = "value" (where if assigned a category value would be returned as Red,Green,Orange,Purple,Aqua, or Blue) against each input in the API. Example: Code:
<input key="0ebbccd4-0db9-46e1-ab9c-ac4ca62acb2f"
       number="49"
       type="Video"
       title="My Video Clipr"
       state="Paused"
       position="0"
       duration="99500"
       loop="False"
       category="Red"
       muted="True"
       volume="38.95008"
       balance="0"
       solo="False"
       audiobusses="M"
       meterF1="0" meterF2="0">
</input>
 Thanks Keith
 Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
                +1
  and the ability to change the input to a particular category via API call.
  eg. SetInputCategory Value,Input
  Change to Category according to Value (All,Red,Green,Orange,Purple,Aqua,Blue) Value = Category Input = Input
