NDI
Full Windows FFMPEG 32/64bit with Decklink, HVENC, CUDA, NPP and NDI.
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
It's taken me a month of Sundays (Mondays, Tuesday and Wednesdays) but finally got a FULL set of fully feature enabled 4.0.2 ffmpeg and tools (ffplay, ffprobe etc.) built for Windows 32/64bit from the latest (4.0.2) source.
Some of those who have used the NewTek ffmpeg build (shipped with SDK 3.5) will notice that 99% of the other devices, codecs and plugins have been disabled in their build. Let alone the fact that all of the tools like ffplay are just missing). You will probably be also aware (as I became) that nobody else is preparing Windows binaries that include the NDI support. For example using the Newtek build you can't suck in an NDI feed and h.264 encode it using the hardware encoders on Gforce or Quadro cards (you can use encode it using the 'software' x.264 encoder), but that's no good if you require to offload encoding to save CPU resources.
Now because of the of the odd miss-mash of licencing of various components (MIT, GPL-2, GPL-3, Nvidia, Blackmagic, Franahoff etc.) I don't think I can legally distribute the windows binaries of my build, but happy to share with friends - I am open to making new friends. :)
This build has EVERY option, codec, device and plug in I can find, and is really designed for protyping, rather than production, however I may be able to help build custom ffmpegs, if you need one optimised.
Just let me know if you would like to 'test' my binaries, I could do with some feedback.
All The Best
Keith
 12 users thanked kgoodyer for this useful post.
stevespaw on 9/5/2018(UTC), ask on 9/13/2018(UTC), mjgraves on 9/13/2018(UTC), BETech on 9/13/2018(UTC), DWAM on 9/15/2018(UTC), raugert on 9/16/2018(UTC), lucimur on 10/18/2018(UTC), krzy on 11/3/2018(UTC), benjamin_video on 1/4/2019(UTC), rickb on 6/23/2019(UTC), regstuff on 7/5/2019(UTC), erzyk on 11/19/2020(UTC)
update: been using this to h.264 encode and rtmp stream eight simultaneous streams out of vMix. What is great is I can encode directly from the 4 x vMix NDI outputs. By setting up the overlays I can now broadcast the same production but with different 'branding' graphics to each distribution platform.
Things I have tried so far....
Decklink HD-SDI input to NDI NDI to Decklink HD-SDI output NDI to rtmp h.264 encoded web stream using NVENC (Quadro / Geforce) rtmp to NDI using NVDEC (Quadro / GeForce) Decklink HD-SDI to h.264 encoded web stream using NVENC (Quadro / Geforce) rtmp to Decklink HD-SDI using NVDEC (Quadro / GeForce) Logitech BRIO webcam 4K to NDI (only tested to 1080p60) Logitech C920 webcam to NDI (Only tested to 1080p30)
NDI to 8 x simultaneous h.264 encode and RTMP stream at multiple resolutions, frame rates and bit rates from 360p25 thru to 1080p50 using Quadro K2000 video card ($100 on ebay). Keith
 3 users thanked kgoodyer for this useful post.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Great job I intended to do but never did! The Newtek version was enough for what I wanted to do but a full version is a very nice tool to have...
I'm very much interested if you still want to share. I'd be happy to test it and report feedback.
Congrats! Guillaume
Joined: 10/17/2018(UTC) Posts: 1  Location: Ottawa Thanks: 2 times
Hi Keith,
I'm very interested in your complete build if this is something that you're still willing to share!
Thanks,
Murray
Greetings Keith
If you still have this I'd be very interested.
Do you have information on what you did to build it?
Trying to understand the instructions on ffmpeg windows builds seems really difficult (it clearly assumes knowledge that I don't have!)
Phil
Hi kgoodyer,
I'm very interested in your build. Please share it.
Thanks!
no reaction of kgoodyer. :(
That would be that nice, to get an ffmpeg with nvenc support.
May be somebody can send me the ffmpeg version?
Thanks!!
Yes i would love to get a copy of this as well for windows...
Joined: 6/4/2020(UTC) Posts: 7  Location: Madison, WI
I Know this thread is old, but it caught my attention.
I managed to find a version of FFMPEG with NDI and decklink support. I’m looking for correct command line arguments to output and NDI to SDI with the decklink module.
I’ve been able to see SDI output on the decline card, but frame rate is poor and ffmpeg reports many duplicated frames.
Hi Keith, if you have an updated version of your complete build of ffmpeg I'd like to try it. Let me know, please. Thank you. Alex :)
Hi Keith
I’d love to test one of your builds. I am very interested in your multi RTMP outputs from NDI.
You have been a member since:: 1/17/2025(UTC) Posts: 2  Was thanked: 1 time(s) in 1 post(s)
Hello Keith,
I am not sure if it is a bit late now, but congratulations on your great job!
If you still have this I'd be very interested in testing it: NDI to av1_nvenc NDI to hevc_nvenc (using an Ada Lovelace family GPU at 4K 30fps)
If you are still willing to share it, I would be more than happy to "test" your build.
Thanks, Blakelin
After a few weekends of struggling, I successfully compiled ffmpeg with libndi_newtek and nvenc/nvdec support for Windows 64 --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-schannel --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvenc --enable-nvdec --enable-cuda-llvm --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libdav1d --enable-libaom --disable-debug --enable-libfdk-aac --enable-gpl --enable-libopenh264 --enable-libndi-newtek --extra-libs=-liconv --enable-version3 The same goes for Keith, I can't distribute it legally, but I can let the community help me "test" this build. I am willing to give some advice and guidance to friends who are trying to build similar staff. Need to note: Since it is ffmpeg5.1.6, the current version does not support av1_nvenc I used media-autobuild_suite to complete this task, The useful references I have looked up are: https://framagit.org/tytan652/ffmpeg-ndi-patchhttps://github.com/m-ab-...ues/1377#issue-488118134https://www.linuxquestio...-4175729366/#post6461184
 1 user thanked blakelin for this useful post.
Joined: 3/28/2016(UTC) Posts: 168   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
i would love to help test and contribute to the project if you're still around. -king Originally Posted by: blakelin  After a few weekends of struggling, I successfully compiled ffmpeg with libndi_newtek and nvenc/nvdec support for Windows 64 --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-schannel --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvenc --enable-nvdec --enable-cuda-llvm --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libdav1d --enable-libaom --disable-debug --enable-libfdk-aac --enable-gpl --enable-libopenh264 --enable-libndi-newtek --extra-libs=-liconv --enable-version3 The same goes for Keith, I can't distribute it legally, but I can let the community help me "test" this build. I am willing to give some advice and guidance to friends who are trying to build similar staff. Need to note: Since it is ffmpeg5.1.6, the current version does not support av1_nvenc I used media-autobuild_suite to complete this task, The useful references I have looked up are: https://framagit.org/tytan652/ffmpeg-ndi-patchhttps://github.com/m-ab-...ues/1377#issue-488118134https://www.linuxquestio...-4175729366/#post6461184
https://github.com/moocowsheep/ffmpeg-ndi-patchHaven't tried this on Windows, but I 100% know this compiles and works on Linux. I've been using this since August 2024. This compiles and works against ffmpeg 7.1.1 and uses the NDI 6 SDK. That said, now with OMT existing, it's a lot easier to just use that.
NDI
