Barney Box Lane
#1 Posted : Saturday, November 17, 2018 12:57:31 AM(UTC)
Barney Box Lane
Hi all,
I'm wondering if it's possible to
mix your output of a match or race and send it to another computer.
in the left channel have the environment sound, engines etc for replays
and in the right have the commentary in sync for the main output with all the titles and commentary etc
or is there just a normal way to send two audio feeds for the same video output that would stay in sync all day?
Thank you )
mjgraves
#2 Posted : Saturday, November 17, 2018 2:28:16 AM(UTC)
mjgraves
Sure. You can send multiple channels between hosts using Dante or VoiceMeeter's VBAN. Like virtual audio cables that are IP-based.
They will be as stable as your network and host computers. Anticipate a little delay. Not more than one frame.
Barney Box Lane on 11/18/2018(UTC)
zenvideo
#3 Posted : Saturday, November 17, 2018 3:14:25 AM(UTC)
zenvideo
You can use NDI to send video and audio to another computer, and all the vMix audio outputs (Master, A & B busses - plus the headphone mix) are available as NDI sources.
In some ways it would be more convenient if there was an option to have all these audio channels included in the main vMix NDI Output stream (as 2/4/6/8 channel audio), much like there is a menu option for Master/A/B/MA/MAB audio in the External Output settings, simply so that only a single NDI source would need selecting/receiving in order to have all the audio channels potentially available.
desmar
#4 Posted : Saturday, November 17, 2018 4:05:21 AM(UTC)
desmar
Canada
+1 for
